Yosemite Beta 10.10.4 - CRASH
marcusrobson1974
Hi there
Been using your product for a number of months but upgraded to OS X Beta 10.10.4 and the app now won't launch. No error messages and nothing in activity monitor, just the whole app does not launch when I click the icon.
Re: Yosemite Beta 10.10.4
marcusrobson1974
We do not have 10.10.4
How to install it?
How to install it?
DreamSeason
There are public betas.Steven wrote:marcusrobson1974
How to install it?
ok, found it, installing
DreamSeason
BTW, what's the plan for next version?Steven wrote:ok, found it, installing
marcusrobson1974
We have updated to 10.10.4 and MFC works fine. Maybe you some more information?
1. Have you tried to reboot?
2. Try run this
DreamSeason
http://forums.crystalidea.com/viewtopic.php?f=11&t=911
http://forums.crystalidea.com/viewtopic.php?f=11&t=1220
2. Try run this
#!/bin/bash
killall MacsFanControl
rm ~/Library/Preferences/com.crystalidea.macsfancontrol.plist
killall -u `id -u -n` cfprefsdhttp://forums.crystalidea.com/viewtopic.php?f=11&t=911
marcusrobson1974
Tried the reboot and the code but appears there are no Crystalidea plists in my Library. I also checked activity monitor and Fan Control is appearing in the Energy section, but nowhere else........the plot thickens!
- Screen Shot 2015-05-25 at 10.07.37 AM.png (45.22 KiB) Viewed 15177 times
- Screen Shot 2015-05-25 at 10.13.37 AM.png (97.48 KiB) Viewed 15177 times
marcusrobson1974
What about Applications->Utilities->Console ?
Anything there when starting MFC?
marcusrobson1974
Here is what comes up in console when i try and launch the app
- Screen Shot 2015-05-25 at 12.21.32 PM.jpg (210.53 KiB) Viewed 15172 times
marcusrobson1974
..and here is the MacsFan crash report
- crash_report.txt
- (38.42 KiB) Downloaded 935 times
Re: Yosemite Beta 10.10.4 - CRASH
marcusrobson1974
Can you try to repair permissions on the mac drive ?
https://support.apple.com/en-us/HT201560
Also you must remove ssdfancontrol if you want to use MFC
PS. Do you have some external 3rd party display?
