hello I installed macs fan against version 1.3.0 I can not change and control the fan speed of the hard disk
tells me resttare smc, I did but remains the same, you know, help me thanks
Fan speed is always the same without the possibility of chan
- min-max fan values are equal (1212).jpg (69.28 KiB) Viewed 6068 times
Re: Fan speed is always the same without the possibility of chan
giaclaf
1. Please show us the main window of the app when it's not covered by other windows
2. Please give us technical information from Preferences->Diagnostics tab
3. Have you used other fan controlling apps? If yes, uninstall them all and reset SMC
