Macs Fan Control 1.3.1 crash when checking for update (10.7)
chrisw
Post by chrisw »
Just upgraded from Macs Fan Control 1.3.0 to 1.3.1 and after running app for a minute or two it quits. I've copied the Tech info below as requested
and this is the report that OSX shows after an app quits
tech_info.txt
(1.25 KiB) Downloaded 1555 times
crash_report.txt
(41.58 KiB) Downloaded 1427 times
Re: Macs Fan Control quitting after update from 1.3.0 to 1.3.1
chrisw
thank you for the feedback. Looks like the reason is in the Qt framework we use :(
https://bugreports.qt.io/browse/QTBUG-48036
Foxlink
Post by Foxlink »
I got the same problem, 1.3.0 worked fine, but when updated, it crashed big time. Thank you Chris for bringing it up. I got the same messages that you have already posted.
DreamSeason
Post by DreamSeason »
Well, it works for me with El Capitan public beta 5.
Re: Macs Fan Control 1.3.1 crash when checking for update
Foxlink
Do you also have OS X 10.7 ?
Mackeyser
Is Mac OS X 10.7.5 still supported?
Post by Mackeyser »
I ask because I have a Mac Pro 1,1 running OS X running 10.7.5 and I upgraded to 1.3.1 and ever since then, I've had issues with Macs Fan Control.
The app quits within a minute or two after launch.
The app will not relaunch when I reawaken the computer.
I had zero issues with 1.3.0. Am I and the other Mac Pro 1,1 users in the same boat and do we need to revert to 1.3?
Or is there a fix?
(I made the mistake of clearing out my downloads folder of a bunch of clutter and because Macs Fan Control had been such a non-issue of an app for so long, I just deleted the .img thinking that I'd just re d/l it if I needed it again. Silly, I know. I should have kept the older version for just in case.)
jhjh
crash after one minute
Post by jhjh »
Recently had an auto-shutdown of system, a day or two after downloading macs fan control update 1.3.1.0 . Since then, macs fan control will open and run for about a minute, then crash. The fan speed stays at whatever it was when the program crashed.
Running Mac OS 10.7.5 on mac mini 1.83 ghz intel core 2 duo
Below is a representative report from crash reporter on the crashed thread.
Any help?
Thread 8 Crashed:: Thread (pooled)
0 dyld 0x8fe0e071 dyld_fatal_error + 1
1 dyld 0x8fe11c9d dyld::fastBindLazySymbol(ImageLoader**, unsigned long) + 140
2 libdyld.dylib 0x9aaf484c dyld_stub_binder_ + 20
3 org.qt-project.QtNetwork 0x0122656b 0x115c000 + 828779
4 org.qt-project.QtNetwork 0x0120fd89 QSslCertificate::QSslCertificate(QByteArray const&, QSsl::EncodingFormat) + 121
5 org.qt-project.QtNetwork 0x0121430b 0x115c000 + 754443
6 org.qt-project.QtNetwork 0x0121295d QSslConfiguration::QSslConfiguration() + 29
7 org.qt-project.QtNetwork 0x011aae41 0x115c000 + 323137
8 org.qt-project.QtNetwork 0x011a8e4e 0x115c000 + 314958
9 org.qt-project.QtNetwork 0x0118cb00 QNetworkAccessManager::createRequest(QNetworkAccessManager::Operation, QNetworkRequest const&, QIODevice*) + 2048
10 org.qt-project.QtNetwork 0x0118af0c QNetworkAccessManager::get(QNetworkRequest const&) + 44
11 com.crystalidea.MacsFanControl 0x0004cccf QHttpFileDownloader::download() + 159
12 com.crystalidea.MacsFanControl 0x00053c6d QUpdateChecker::updateCheckThread() + 157
13 com.crystalidea.MacsFanControl 0x0005ccd1 QtConcurrent::VoidStoredMemberFunctionPointerCall0<void, QUpdateChecker>::runFunctor() + 33
14 com.crystalidea.MacsFanControl 0x00027598 QtConcurrent::RunFunctionTask<void>::run() + 40
15 com.crystalidea.MacsFanControl 0x00027664 non-virtual thunk to QtConcurrent::RunFunctionTask<void>::run() + 20
16 org.qt-project.QtCore 0x00c270a9 0xbf2000 + 217257
17 org.qt-project.QtCore 0x00c2a6a7 0xbf2000 + 231079
18 libsystem_c.dylib 0x93e41ed9 _pthread_start + 335
19 libsystem_c.dylib 0x93e456de thread_start + 34
I'm working on a workaround fix to disable checking for updates
Re: Macs Fan Control 1.3.1 crash when checking for update (10.7)
Please re-download, everybody. Must be fixed now. Thank you.
Foxlink
Post by Foxlink »
Steven wrote:Foxlink
Yes, I'm running 10.7.5, my Mac is one of the older models, actually the first 1.1 Mac Pro.
Thank you everyone for putting so much work into it, I'll update and see if I don't get any crashes again. 8-)
jhjh
Post by jhjh »
Thanks for fix, I downloaded again and it's working now without crashing. Also checked for updates and did not have any problem.
jhjh
Post by jhjh »
updated to 1.3.2 and it is doing the same thing the 1.3.1 update did before the fix (see post from september 2nd). i.e. crashing after one minute. please fix again!
jhjh
Please re-download it (fixed again this for 10.7)
andee
Post by andee »
Steven wrote:jhjh
Thanks for the fix.
I still use 10.7.5, and this program is one of, if not the most essential and important utility I use.
Thank you Crystalidea!
:good:
