MFC is working,but I can not open the MFC's windows
PureViewGQ
Post by PureViewGQ »
Hello
I have a iMac(MD096) running MFC on Windows10Pro with bootcamp. I have used MFC long times and It's works good,But a few days ago,I update the MFC to 1.3.2.It also works good now,It can control my fan with the CPU TEMP,But I can not open the MFC's main window,I Click the "Show Macs fan control" There is no window showing,Task bar show a MFC button,but I click it,nothing happen. I uninstall it then reinstall,It's also can't show the main windows.And I tried the low Ver like 1.3.1, It's also can't show the main window.I think It's the configuration file problem,Because when I uninstall it And del all the MFC files at C:\Program Files (x86)\Macs Fan Control,then reinstall,It's also has the fan control config.Maybe It's the config problem
PS:I click Show Macs Fan Control at 1.png,then task bar has an MFC icon at 2.png,If I click this icon nothing happen and this icon will disappear.3.png We can see this windows,It's not worked
INFO  2015-10-18T12:28:51.001 app.cpp @ 158 "Macs Fan Control 1.3.2"
INFO  2015-10-18T12:28:51.001 app.cpp @ 159 "Windows Unknown x64"
INFO  2015-10-18T12:28:51.001 app.cpp @ 160 "iMac13,2"
INFO  2015-10-18T12:28:51.001 app.cpp @ 161 "Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz"
INFO  2015-10-18T12:28:51.001 app.cpp @ 162 "Qt 5.5.0"
INFO  2015-10-18T12:28:51.001 core\smc_win.cpp @ 62 "QSmcControlWin::Open: Using standard port X"
INFO  2015-10-18T12:28:51.027 core\FanControl.cpp @ 318 "QFanControl::Init"
INFO  2015-10-18T12:28:51.027 core\FanControl.cpp @ 332 "QFanControl::Init - LoadCachedFansAndTempSensors"
INFO  2015-10-18T12:28:51.027 core\FanControl.cpp @ 337 "QFanControl::Init - FilterSupportedTempSensors"
INFO  2015-10-18T12:28:51.028 core\FanControl.cpp @ 341 "QFanControl::Init - smc_get_fans_control_mode"
INFO  2015-10-18T12:28:51.029 core\FanControl.cpp @ 82 "Fan " 0 ": manual"
INFO  2015-10-18T12:28:51.029 core\FanControl.cpp @ 345 "QFanControl::Init - QTempSensorSmart::loadAvailableSensors"
INFO  2015-10-18T12:28:51.029 core\TempSensorSmart_win.cpp @ 232 "Loading available SMART drives"
INFO  2015-10-18T12:28:51.029 core\TempSensorSmart_win.cpp @ 243 "GetLogicalDrives returned 12"
INFO  2015-10-18T12:28:51.029 core\TempSensorSmart_win.cpp @ 253 "Checking drive C:\\"
INFO  2015-10-18T12:28:51.029 core\TempSensorSmart_win.cpp @ 261 "Drive is fixed"
INFO  2015-10-18T12:28:51.029 core\TempSensorSmart_win.cpp @ 277 "Phisical disk number: 1"
INFO  2015-10-18T12:28:51.031 core\TempSensorSmart_win.cpp @ 303 "Adding drive \\\\.\\PHYSICALDRIVE1"
WARN  2015-10-18T12:28:51.031 core\smc.cpp @ 366 "smc_get_temp - skipping sensor TH0A with value of 129"
INFO  2015-10-18T12:28:51.031 core\TempSensorSmart_win.cpp @ 309 "Adding drive APPLE SSD SM128E"
INFO  2015-10-18T12:28:51.031 core\TempSensorSmart_win.cpp @ 253 "Checking drive D:\\"
INFO  2015-10-18T12:28:51.031 core\TempSensorSmart_win.cpp @ 261 "Drive is fixed"
INFO  2015-10-18T12:28:51.031 core\TempSensorSmart_win.cpp @ 277 "Phisical disk number: 0"
INFO  2015-10-18T12:28:51.032 core\TempSensorSmart_win.cpp @ 303 "Adding drive \\\\.\\PHYSICALDRIVE0"
INFO  2015-10-18T12:28:51.032 core\TempSensorSmart_win.cpp @ 309 "Adding drive APPLE HDD ST1000DM003"
INFO  2015-10-18T12:28:51.032 core\FanControl.cpp @ 349 "QFanControl::Init: number of supported SMC sensors: 4"
INFO  2015-10-18T12:28:51.032 core\FanControl.cpp @ 350 "QFanControl::Init: number of supported SMART sensors: 2"
INFO  2015-10-18T12:28:51.032 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:28:52.073 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:28:52.073 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:29:23.086 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:29:54.093 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyDoNothing, Temperature 50, RPM=1202"
INFO  2015-10-18T12:29:54.093 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:29:54.093 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:29:55.094 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:29:55.094 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1201
INFO  2015-10-18T12:29:56.094 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:30:27.110 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:30:58.124 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:31:29.137 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:32:00.147 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:32:31.157 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:02.166 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:13.171 core\SensorControl.cpp @ 109 "Main: HALF INCREASE ON"
INFO  2015-10-18T12:33:13.171 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyIncrease, Temperature 50, RPM=1200"
INFO  2015-10-18T12:33:13.171 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1201
INFO  2015-10-18T12:33:13.171 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:14.172 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:33:21.176 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyDoNothing, Temperature 50, RPM=1203"
INFO  2015-10-18T12:33:21.176 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1203
INFO  2015-10-18T12:33:21.176 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:22.176 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:33:29.179 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyDoNothing, Temperature 50, RPM=1202"
INFO  2015-10-18T12:33:29.179 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:33:29.179 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:30.180 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:33:35.182 core\SensorControl.cpp @ 109 "Main: HALF INCREASE ON"
INFO  2015-10-18T12:33:35.182 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyIncrease, Temperature 50, RPM=1199"
INFO  2015-10-18T12:33:35.182 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1201
INFO  2015-10-18T12:33:35.182 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:36.182 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:33:37.183 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1203
INFO  2015-10-18T12:33:38.183 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:33:44.185 core\SensorControl.cpp @ 109 "Main: HALF INCREASE ON"
INFO  2015-10-18T12:33:44.185 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyIncrease, Temperature 50, RPM=1194"
INFO  2015-10-18T12:33:44.185 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1201
INFO  2015-10-18T12:33:44.185 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:45.186 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:33:46.187 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1203
INFO  2015-10-18T12:33:47.187 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1204
INFO  2015-10-18T12:33:48.187 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1205
INFO  2015-10-18T12:33:49.188 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1206
INFO  2015-10-18T12:33:50.189 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1207
INFO  2015-10-18T12:33:51.189 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:33:55.190 core\SensorControl.cpp @ 109 "Main: HALF INCREASE ON"
INFO  2015-10-18T12:33:55.190 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyIncrease, Temperature 50, RPM=1200"
INFO  2015-10-18T12:33:55.190 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1201
INFO  2015-10-18T12:33:55.190 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:33:56.190 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:33:57.190 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1203
INFO  2015-10-18T12:33:58.191 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:34:00.192 core\SensorControl.cpp @ 114 "Main: Tendency is set to TendencyDoNothing, Temperature 50, RPM=1204"
INFO  2015-10-18T12:34:00.192 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1204
INFO  2015-10-18T12:34:01.192 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:34:01.192 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1203
INFO  2015-10-18T12:34:02.192 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:34:03.192 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1201
INFO  2015-10-18T12:34:04.192 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:34:04.192 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:34:35.205 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:35:04.212 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:35:04.212 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:35:06.212 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:35:37.221 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:36:04.228 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:36:04.228 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:36:08.229 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:36:39.238 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:37:04.244 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:37:04.244 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:37:10.245 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:37:41.258 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:38:04.268 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:38:04.268 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:38:12.271 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:38:43.281 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:39:04.291 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:39:04.291 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:39:14.296 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:39:45.309 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:40:04.315 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:40:04.315 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:40:16.319 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:40:47.331 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:41:09.337 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:41:09.337 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:41:18.341 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:41:49.356 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:42:13.365 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:42:13.365 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:42:20.367 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:42:51.377 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:43:22.386 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:43:22.386 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:43:22.386 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:43:53.397 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:44:24.410 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:44:36.414 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:44:36.414 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:44:55.419 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:45:26.428 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:45:41.432 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:45:41.432 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:45:57.437 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:46:28.446 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:46:41.451 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:46:41.451 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:46:59.456 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:47:30.467 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:47:53.475 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:47:53.475 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:48:01.477 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:48:32.485 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:49:03.494 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:49:05.495 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:49:05.495 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:49:34.504 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:50:05.513 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:50:11.515 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:50:11.515 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:50:36.521 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:51:07.530 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:51:11.532 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:51:11.532 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:51:38.540 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:52:09.551 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:52:14.552 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:52:14.552 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:52:40.565 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:53:11.580 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:53:14.581 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:53:14.581 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:53:42.594 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:54:07.602 core\SensorControl.cpp @ 212 "Main: Temperature INCREASED to 51"
INFO  2015-10-18T12:54:07.602 core\SensorControl.cpp @ 290 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:07.602 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:54:07.602 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:54:08.602 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:08.602 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:08.602 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:08.602 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1204
INFO  2015-10-18T12:54:09.603 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:09.603 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:09.603 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:09.603 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1206
INFO  2015-10-18T12:54:10.603 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:10.603 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:10.603 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:10.603 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1208
INFO  2015-10-18T12:54:11.603 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:11.603 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:11.603 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:11.603 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1210
INFO  2015-10-18T12:54:12.603 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1212
INFO  2015-10-18T12:54:13.604 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:13.604 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:13.604 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:13.604 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1214
INFO  2015-10-18T12:54:14.604 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:14.604 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:14.604 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:14.604 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1216
INFO  2015-10-18T12:54:15.604 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:15.604 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:15.604 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:15.604 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1218
INFO  2015-10-18T12:54:16.605 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:16.605 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:16.605 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:16.605 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1220
INFO  2015-10-18T12:54:17.606 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:17.606 core\SensorControl.cpp @ 183 "Main: Ignoring temperature change"
INFO  2015-10-18T12:54:17.606 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyIncrease"
INFO  2015-10-18T12:54:17.606 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1222
INFO  2015-10-18T12:54:18.606 core\SensorControl.cpp @ 159 "Main: Temperature DECREASED to 50"
INFO  2015-10-18T12:54:18.606 core\SensorControl.cpp @ 208 "Main: Tendency is set to TendencyDoNothing"
INFO  2015-10-18T12:54:48.616 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:55:18.625 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:55:18.625 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1221
INFO  2015-10-18T12:55:18.625 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:55:19.626 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1220
INFO  2015-10-18T12:55:20.626 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1219
INFO  2015-10-18T12:55:21.626 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1218
INFO  2015-10-18T12:55:22.627 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1217
INFO  2015-10-18T12:55:23.627 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1216
INFO  2015-10-18T12:55:24.627 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1215
INFO  2015-10-18T12:55:25.628 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1214
INFO  2015-10-18T12:55:26.628 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1213
INFO  2015-10-18T12:55:27.628 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1212
INFO  2015-10-18T12:55:28.628 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1211
INFO  2015-10-18T12:55:29.628 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1210
INFO  2015-10-18T12:55:30.629 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1209
INFO  2015-10-18T12:55:31.629 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1208
INFO  2015-10-18T12:55:32.629 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1207
INFO  2015-10-18T12:55:33.629 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1206
INFO  2015-10-18T12:55:34.630 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1205
INFO  2015-10-18T12:55:35.630 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1204
INFO  2015-10-18T12:55:36.630 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1203
INFO  2015-10-18T12:55:37.631 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1202
INFO  2015-10-18T12:55:38.631 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1201
INFO  2015-10-18T12:55:39.631 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:55:39.631 core\SensorControl.cpp @ 393 "Main: Setting fan speed to" 1200
INFO  2015-10-18T12:56:10.639 core\smc.cpp @ 324 Set fans mode 1
INFO  2015-10-18T12:56:39.646 core\SensorControl.cpp @ 143 "Main: HALF DECREASE ON"
INFO  2015-10-18T12:56:39.646 core\SensorControl.cpp @ 374 "Main: PEEK MIN RPM '1200' for current temperature, do nothing now"
INFO  2015-10-18T12:56:41.646 core\smc.cpp @ 324 Set fans mode 1
Re: MFC is working,but I can not open the MFC's windows
PureViewGQ
Try to delete the key please
HKEY_CURRENT_USER\Software\CrystalIdea Software\Macs Fan Control
