Hello there and happy holidays.
There is one thing I do not like about SpeedyFox- it cannot be run in portable mode. I tested the PortableApps package of SpeedyFox but I did not like it because it starts much slower compared to the original program.
I would like to suggest either a separate portable version of SpeedyFox which saves its settings inside program folder or if there is a file preferences.xml inside program folder SpeedyFox should use it and should not create a new one in AppData (C:\Users\UserName\AppData\Roaming\CrystalIdea Software\SpeedyFox\preferences.xml).
Regards
