MacsFan Control freeze version 1.3.3
Naure
Post by Naure »
Since the version 1.3.2, a bug is appeared. The application "freeze" and I have to quit and re launch to run the application. but after after doing this, the application freeze after a few seconds. this bug is only on "automatically mode". I have an MacBook Pro Retina, 13 inch, late 2013.
sorry for my bad english.
Re: MacsFan Control freeze version 1.3.3
Naure
Can you record a video?
Naure
Post by Naure »
Naure
1. Does it freeze temperature/fan readings every time you launch the app?
2. Can you give me the System Console utility log?
Naure
Post by Naure »
hi,
I noticed that if I do not open applications other than the startup , the application does not freeze . if I open other applications ( I tested with google chrome numbers and pages ) MacFan control freeze. uninstall and reinstall does not change the problem.
MacsFanControl - copie.log
(1.56 KiB) Downloaded 991 times
Naure
Post by Naure »
Hi, here is what I found in the console relating to MacsFan control
filtre mcfancontrol.log
(18.43 KiB) Downloaded 1112 times
