Version 1.4 - unsupported hardware
Asphalter
Post by Asphalter »
Upgraded to version 1.4 and now Macs Fan Control does not work on my Retina MacBook Pro.
"Unsupported hardware detected"
Going back to version 1.3.3 now gives the same message.
Re: Version 1.4 Does not work on Mid 2012 Retina MacBook Pro
Asphalter
1. which Windows are you using?
2. What do you have under
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SystemInformation
(export this registry key or make a screenshot)
Asphalter
Post by Asphalter »
1. Using Windows 7
2. Please see attached screenshot.
Asphalter
Don't know why it's empty.
Should be something like that
Asphalter
Re: Version 1.4 - unsupported hardware
Post by Asphalter »
Interesting, maybe my boot camp driver has become corrupted.
Thanks for the quick reply.
Asphalter
Please run this tool
http://www.crystalidea.com/downloads/dmidecode.zip
And redirect its output to some text file. E.g. open cmd.exe and type there
dmidecode.exe > output.txt
After that, please attach this output.txt file here.
Asphalter
Post by Asphalter »
Here's the file.
output.txt
(12.51 KiB) Downloaded 1807 times
Asphalter
Please try the dev version, it should work
http://www.crystalidea.com/downloads/ma ... up_dev.exe
Alternative solution
Well, it means this utility correctly detects the hardware. Please create 2 string values SystemManufacturer and SystemProductName matching the output.txt:
Manufacturer: Apple Inc.
Product Name: MacBookPro11,3
in
in order to let the app work. I'll fix this in 1.4.1
Asphalter
Post by Asphalter »
I couldn't get the reg fix to work with 1.4.0 but the dev version 1.4.1 allows me to change fan speed (which is the main use of the app to me).
Thanks very much.
Asphalter
Great! The fix will be in the official 1.4.1 version
Asphalter
Post by Asphalter »
One more thing - the temperature values are missing on the right in the screenshot there.
Asphalter
i'm sorry for this, this is a beta version. I'll make a new build in a week.
Asphalter
Please re-download the dev version, it should give a message on startup, please give me the text of this message (Ctrl+C)
