Cant give helper app permissions...?
steveyg777
Post by steveyg777 »
Screenshot 2016-04-03 at 10.17.43 pm.png (38.1 KiB) Viewed 20068 times
Screenshot 2016-04-03 at 10.17.32 pm.png (33.01 KiB) Viewed 20068 times
Screenshot 2016-04-03 at 10.17.03 pm.png (72.85 KiB) Viewed 20068 times
this happens when i load the app up. it asks for password (which IS correct) and then throws up this error. here is the diagnostics:
Macs Fan Control 1.4.0
iMac14,2
Intel(R) Core(TM) i7-4771 CPU @ 3.50GHz[100]
Mac OS X 10.11.4
Main-min{1200}curr{1394}max{2640}mode{2,TC0c,50,75}
TA0P () - 12.25, 12.25
TA0V () - 17.3828, 17.3828
TA0p (Ambient) - 32.25, 32.25
TC0E () - -1, 248.922
TC0F () - -1, 249.746
TC0J () - 0.824219, 0.824219
TC0P () - 69, 69
TC0T () - 0.0703125, 0.0703125
TC0c (CPU Core 1) - 93, 93
TC0p (CPU Proximity) - 69, 69
TC1c (CPU Core 2) - 93, 93
TC2c (CPU Core 3) - 94, 94
TC3c (CPU Core 4) - 90, 90
TCGc (GPU PECI) - 77, 77
TCSc () - 74, 74
TCXR () - -1, 250.109
TCXc (CPU PECI) - 94.1094, 94.1094
TCXr () - -1, 250.109
TG0D () - 50, 50
TG0E () - 50.0078, 50.0078
TG0F () - 51.293, 51.293
TG0J () - 1.28516, 1.28516
TG0P () - 45.375, 45.375
TG0T () - -1, 255.965
TG0d (GPU Diode) - 41, 41
TG0p (GPU Proximity) - 45.375, 45.375
TH0A () - -1, 129
TH0B () - -1, 129
TH0C () - -1, 129
TH0F () - -1, 129
TH0O () - -1, 249
TH0P () - -1, 249
TH0R () - -1, 129
TH0a () - -1, 129
TH0b () - -1, 129
TH0c () - -1, 129
TH0e () - -1, 0
TH1A () - -1, 129
TH1B () - -1, 129
TH1C () - -1, 129
TH1F () - -1, 129
TH1O () - 9, 9
TH1P () - -1, 129
TH1R () - -1, 129
TH1a () - -1, 129
TH1b () - -1, 129
TH1c () - -1, 129
TL0P () - 26, 26
TL0V () - 21.1484, 21.1484
TL0p (LCD proximity) - 26, 26
TL1P () - 29, 29
TL1V () - 20.9727, 20.9727
TL1p () - 29, 29
TL1v () - 21.0039, 21.0039
TM0P () - 43.25, 43.25
TM0V () - 54, 54
TM0p (DIMM Module 1 Proximity) - 43.25, 43.25
TM1P () - 34.125, 34.125
TM1a () - 60.6484, 60.6484
TM1p (DIMM Module 2 Proximity) - 34.125, 34.125
TM2P () - 39.75, 39.75
TM2a () - 53.8047, 53.8047
TM2b () - 56.8047, 56.8047
TM2c () - 53.8047, 53.8047
TM2d () - 56.8047, 56.8047
TM2p (DIMM Module 3 Proximity) - 39.75, 39.75
TM3P () - 38.375, 38.375
TM3a () - 50.8047, 50.8047
TM3b () - 48.8047, 48.8047
TM3c () - 53.125, 53.125
TM3d () - 50.8047, 50.8047
TM3p (DIMM Module 4 Proximity) - 38.375, 38.375
TM4a () - 54, 54
TMXP () - 43.25, 43.25
TPCD (Platform Controller Hub Die) - 45, 45
TS0V () - 33.6953, 33.6953
Tb0P () - 29.875, 29.875
Tb0p () - 29.875, 29.875
Tm0P () - 48.125, 48.125
Tm0p () - 48.125, 48.125
Tm1P () - 38.375, 38.375
Tm1p () - 38.375, 38.375
Tm2P () - 62.25, 62.25
Tm2p () - 62.25, 62.25
Tp2F () - 33.8867, 33.8867
Tp2H () - 33.875, 33.875
Tp2h () - 33.875, 33.875
APPLE HDD ST1000DM003 - 31
PS-to anyone who wants to post a problem and has to include the diagnostics info be aware that (at least in my case) it added my system password to the end of the document(!) which is really not good for security or privacy obviously - just check and delete it off it happens to you :)
Steve
Re: Cant give helper app permissions...?
Hello, steveyg777
Please provide the log from Console when the app tries starts and you enter the password. Error messages should be there
steveyg777
iMac14,2
Mac OS X 10.11.4
Main-min{1200}curr{1302}max{2640}mode{2,TC0c,50,75}
TA0P () - 14.5, 14.5
TA0V () - 18.0156, 18.0156
TA0p (Ambient) - 34.5, 34.5
TC0E () - -1, 247.617
TC0F () - -1, 249.324
TC0J () - 1.70703, 1.70703
TC0P () - 70.625, 70.625
TC0T () - 0.0390625, 0.0390625
TC0c (CPU Core 1) - 90, 90
TC0p (CPU Proximity) - 70.625, 70.625
TC1c (CPU Core 2) - 89, 89
TC2c (CPU Core 3) - 86, 86
TC3c (CPU Core 4) - 91, 91
TCSc () - 74, 74
TCXR () - -1, 247.422
TCXc (CPU PECI) - 91.4219, 91.4219
TCXr () - -1, 247.422
TG0D () - 51, 51
TG0E () - 51.2891, 51.2891
TG0F () - 52.2773, 52.2773
TG0J () - 0.988281, 0.988281
TG0P () - 47.25, 47.25
TG0T () - 0.00390625, 0.00390625
TG0d (GPU Diode) - 42, 42
TG0p (GPU Proximity) - 47.25, 47.25
TH0A () - -1, 129
TH0B () - -1, 129
TH0C () - -1, 129
TH0F () - -1, 129
TH0O () - -1, 249
TH0P () - -1, 249
TH0R () - -1, 129
TH0a () - -1, 129
TH0b () - -1, 129
TH0c () - -1, 129
TH0e () - -1, 0
TH1A () - -1, 129
TH1B () - -1, 129
TH1C () - -1, 129
TH1F () - -1, 129
TH1O () - 9, 9
TH1P () - -1, 129
TH1R () - -1, 129
TH1a () - -1, 129
TH1b () - -1, 129
TH1c () - -1, 129
TL0P () - 29, 29
TL0V () - 24.0352, 24.0352
TL0p (LCD proximity) - 29, 29
TL1P () - 31.25, 31.25
TL1V () - 22.9609, 22.9609
TL1p () - 31.25, 31.25
TL1v () - 23.0195, 23.0195
TM0P () - 45.5, 45.5
TM0V () - 55.168, 55.168
TM0p (DIMM Module 1 Proximity) - 45.5, 45.5
TM1P () - 35.875, 35.875
TM1a () - 61.5508, 61.5508
TM1p (DIMM Module 2 Proximity) - 35.875, 35.875
TM2P () - 41.875, 41.875
TM2a () - 55.1289, 55.1289
TM2b () - 58.1289, 58.1289
TM2c () - 55.1289, 55.1289
TM2d () - 58.1289, 58.1289
TM2p (DIMM Module 3 Proximity) - 41.875, 41.875
TM3P () - 40.75, 40.75
TM3a () - 52.1289, 52.1289
TM3b () - 50.1289, 50.1289
TM3c () - 54.7422, 54.7422
TM3d () - 52.1289, 52.1289
TM3p (DIMM Module 4 Proximity) - 40.75, 40.75
TM4a () - 55.168, 55.168
TMXP () - 45.5, 45.5
TPCD (Platform Controller Hub Die) - 48, 48
TS0V () - 36.0195, 36.0195
Tb0P () - 41.125, 41.125
Tb0p () - 41.125, 41.125
Tm0P () - 50.5, 50.5
Tm0p () - 50.5, 50.5
Tm1P () - 40.75, 40.75
Tm1p () - 40.75, 40.75
Tm2P () - 63.75, 63.75
Tm2p () - 63.75, 63.75
Tp2F () - 37.0312, 37.0312
Tp2H () - 37, 37
Tp2h () - 37, 37
APPLE HDD ST1000DM003 - 33
is this right? or how do i do that?
steveyg777
i found out how to do that btw. here it is:
INFO 2016-04-04T11:51:19.864 MacFanControl/app.cpp @ 191 "Macs Fan Control 1.4.0"
INFO 2016-04-04T11:51:19.864 MacFanControl/app.cpp @ 192 "Mac OS X 10.11.4"
INFO 2016-04-04T11:51:19.864 MacFanControl/app.cpp @ 193 "iMac14,2"
INFO 2016-04-04T11:51:19.865 MacFanControl/app.cpp @ 194 "Intel(R) Core(TM) i7-4771 CPU @ 3.50GHz"
INFO 2016-04-04T11:51:19.865 MacFanControl/app.cpp @ 195 "Qt 5.5.1"
INFO 2016-04-04T11:51:28.171 MacFanControl/core/FanControl.cpp @ 253 "QFanControl::InitialLoadThread"
INFO 2016-04-04T11:51:28.171 MacFanControl/core/FanControl.cpp @ 267 "QFanControl::InitialLoadThread - LoadCachedFansAndTempSensors"
INFO 2016-04-04T11:51:28.171 MacFanControl/core/FanControl.cpp @ 272 "QFanControl::InitialLoadThread - smc_get_fans_control_mode"
INFO 2016-04-04T11:51:28.172 MacFanControl/core/FanControl.cpp @ 79 "Fan " 0 ": auto"
INFO 2016-04-04T11:51:28.172 MacFanControl/core/FanControl.cpp @ 276 "QFanControl::InitialLoadThread - QTempSensorSmart::loadAvailableSensors"
INFO 2016-04-04T11:51:28.177 MacFanControl/core/FanControl.cpp @ 280 "QFanControl::InitialLoadThread - FilterSupportedTempSensors"
INFO 2016-04-04T11:51:28.183 MacFanControl/core/FanControl.cpp @ 293 "QFanControl::InitialLoadThread: number of supported SMC sensors: 16"
INFO 2016-04-04T11:51:28.183 MacFanControl/core/FanControl.cpp @ 294 "QFanControl::InitialLoadThread: number of supported SMART sensors: 1"
INFO 2016-04-04T11:51:28.247 MacFanControl/core/smc.cpp @ 324 Set fans mode 1
WARN 2016-04-04T11:51:40.080 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TC0E with value of 247.617"
WARN 2016-04-04T11:51:40.080 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TC0F with value of 249.324"
WARN 2016-04-04T11:51:40.084 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TCXR with value of 247.422"
WARN 2016-04-04T11:51:40.084 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TCXr with value of 247.422"
WARN 2016-04-04T11:51:40.087 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0A with value of 129"
WARN 2016-04-04T11:51:40.087 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0B with value of 129"
WARN 2016-04-04T11:51:40.088 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0C with value of 129"
WARN 2016-04-04T11:51:40.088 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0F with value of 129"
WARN 2016-04-04T11:51:40.088 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0O with value of 249"
WARN 2016-04-04T11:51:40.089 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0P with value of 249"
WARN 2016-04-04T11:51:40.089 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0R with value of 129"
WARN 2016-04-04T11:51:40.089 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0a with value of 129"
WARN 2016-04-04T11:51:40.090 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0b with value of 129"
WARN 2016-04-04T11:51:40.090 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0c with value of 129"
WARN 2016-04-04T11:51:40.090 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0e with value of 0"
WARN 2016-04-04T11:51:40.090 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1A with value of 129"
WARN 2016-04-04T11:51:40.091 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1B with value of 129"
WARN 2016-04-04T11:51:40.091 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1C with value of 129"
WARN 2016-04-04T11:51:40.091 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1F with value of 129"
WARN 2016-04-04T11:51:40.092 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1P with value of 129"
WARN 2016-04-04T11:51:40.092 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1R with value of 129"
WARN 2016-04-04T11:51:40.092 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1a with value of 129"
WARN 2016-04-04T11:51:40.093 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1b with value of 129"
WARN 2016-04-04T11:51:40.093 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1c with value of 129"
INFO 2016-04-04T21:47:30.285 MacFanControl/app.cpp @ 191 "Macs Fan Control 1.4.0"
INFO 2016-04-04T21:47:30.285 MacFanControl/app.cpp @ 192 "Mac OS X 10.11.4"
INFO 2016-04-04T21:47:30.285 MacFanControl/app.cpp @ 193 "iMac14,2"
INFO 2016-04-04T21:47:30.285 MacFanControl/app.cpp @ 194 "Intel(R) Core(TM) i7-4771 CPU @ 3.50GHz"
INFO 2016-04-04T21:47:30.285 MacFanControl/app.cpp @ 195 "Qt 5.5.1"
INFO 2016-04-04T21:47:54.284 MacFanControl/core/FanControl.cpp @ 253 "QFanControl::InitialLoadThread"
INFO 2016-04-04T21:47:54.284 MacFanControl/core/FanControl.cpp @ 267 "QFanControl::InitialLoadThread - LoadCachedFansAndTempSensors"
INFO 2016-04-04T21:47:54.284 MacFanControl/core/FanControl.cpp @ 272 "QFanControl::InitialLoadThread - smc_get_fans_control_mode"
INFO 2016-04-04T21:47:54.284 MacFanControl/core/FanControl.cpp @ 79 "Fan " 0 ": auto"
INFO 2016-04-04T21:47:54.284 MacFanControl/core/FanControl.cpp @ 276 "QFanControl::InitialLoadThread - QTempSensorSmart::loadAvailableSensors"
INFO 2016-04-04T21:47:54.425 MacFanControl/core/FanControl.cpp @ 280 "QFanControl::InitialLoadThread - FilterSupportedTempSensors"
INFO 2016-04-04T21:47:54.802 MacFanControl/core/FanControl.cpp @ 293 "QFanControl::InitialLoadThread: number of supported SMC sensors: 16"
INFO 2016-04-04T21:47:54.802 MacFanControl/core/FanControl.cpp @ 294 "QFanControl::InitialLoadThread: number of supported SMART sensors: 1"
INFO 2016-04-04T21:47:55.180 MacFanControl/core/smc.cpp @ 324 Set fans mode 1
INFO 2016-04-04T21:59:29.612 MacFanControl/core/FanControl.cpp @ 593 waitForThreadsFinished: Quit OK
INFO 2016-04-04T22:46:32.914 MacFanControl/app.cpp @ 191 "Macs Fan Control 1.4.0"
INFO 2016-04-04T22:46:32.914 MacFanControl/app.cpp @ 192 "Mac OS X 10.11.4"
INFO 2016-04-04T22:46:32.914 MacFanControl/app.cpp @ 193 "iMac14,2"
INFO 2016-04-04T22:46:32.914 MacFanControl/app.cpp @ 194 "Intel(R) Core(TM) i7-4771 CPU @ 3.50GHz"
INFO 2016-04-04T22:46:32.914 MacFanControl/app.cpp @ 195 "Qt 5.5.1"
INFO 2016-04-04T22:46:41.290 MacFanControl/core/FanControl.cpp @ 253 "QFanControl::InitialLoadThread"
INFO 2016-04-04T22:46:41.290 MacFanControl/core/FanControl.cpp @ 267 "QFanControl::InitialLoadThread - LoadCachedFansAndTempSensors"
INFO 2016-04-04T22:46:41.290 MacFanControl/core/FanControl.cpp @ 272 "QFanControl::InitialLoadThread - smc_get_fans_control_mode"
INFO 2016-04-04T22:46:41.290 MacFanControl/core/FanControl.cpp @ 79 "Fan " 0 ": auto"
INFO 2016-04-04T22:46:41.290 MacFanControl/core/FanControl.cpp @ 276 "QFanControl::InitialLoadThread - QTempSensorSmart::loadAvailableSensors"
INFO 2016-04-04T22:46:41.322 MacFanControl/core/FanControl.cpp @ 280 "QFanControl::InitialLoadThread - FilterSupportedTempSensors"
INFO 2016-04-04T22:46:41.329 MacFanControl/core/FanControl.cpp @ 293 "QFanControl::InitialLoadThread: number of supported SMC sensors: 16"
INFO 2016-04-04T22:46:41.329 MacFanControl/core/FanControl.cpp @ 294 "QFanControl::InitialLoadThread: number of supported SMART sensors: 1"
INFO 2016-04-04T22:46:41.394 MacFanControl/core/smc.cpp @ 324 Set fans mode 1
WARN 2016-04-04T22:46:47.545 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TC0E with value of 238.422"
WARN 2016-04-04T22:46:47.545 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TC0F with value of 239.957"
WARN 2016-04-04T22:46:47.549 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TCXR with value of 239.734"
WARN 2016-04-04T22:46:47.549 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TCXr with value of 239.734"
WARN 2016-04-04T22:46:47.551 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TG0T with value of 0"
WARN 2016-04-04T22:46:47.552 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0A with value of 129"
WARN 2016-04-04T22:46:47.552 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0B with value of 129"
WARN 2016-04-04T22:46:47.552 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0C with value of 129"
WARN 2016-04-04T22:46:47.553 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0F with value of 129"
WARN 2016-04-04T22:46:47.553 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0O with value of 249"
WARN 2016-04-04T22:46:47.553 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0P with value of 249"
WARN 2016-04-04T22:46:47.554 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0R with value of 129"
WARN 2016-04-04T22:46:47.554 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0a with value of 129"
WARN 2016-04-04T22:46:47.554 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0b with value of 129"
WARN 2016-04-04T22:46:47.555 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0c with value of 129"
WARN 2016-04-04T22:46:47.555 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH0e with value of 0"
WARN 2016-04-04T22:46:47.555 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1A with value of 129"
WARN 2016-04-04T22:46:47.556 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1B with value of 129"
WARN 2016-04-04T22:46:47.556 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1C with value of 129"
WARN 2016-04-04T22:46:47.556 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1F with value of 129"
WARN 2016-04-04T22:46:47.557 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1P with value of 129"
WARN 2016-04-04T22:46:47.558 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1R with value of 129"
WARN 2016-04-04T22:46:47.558 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1a with value of 129"
WARN 2016-04-04T22:46:47.558 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1b with value of 129"
WARN 2016-04-04T22:46:47.558 MacFanControl/core/smc.cpp @ 366 "smc_get_temp - skipping sensor TH1c with value of 129"
steveyg777
Hello!?
steveyg777
I asked for log from system Console app
http://computers.tutsplus.com/tutorials ... -mac-45251
steveyg777
from your very limited information and from looking at that link this is what i've managed to obtain. i hope this is right because this is taking ages:
04/04/2016 9:47:50.623 pm MacsFanControl[601]: wasLaunchedAsLoginItem: TRUE
06/04/2016 12:05:39.199 am MacsFanControl[374]: wasLaunchedAsLoginItem: TRUE
07/04/2016 1:00:27.234 am MacsFanControl[374]: slotEnteringSleepMode
07/04/2016 2:18:37.933 am MacsFanControl[374]: slotWakeUp
08/04/2016 12:23:22.552 pm MacsFanControl[473]: wasLaunchedAsLoginItem: TRUE
11/04/2016 1:34:16.422 am MacsFanControl[464]: wasLaunchedAsLoginItem: TRUE
it doesn't look very helpful to me but that is all it came up with
steveyg777
don't worry, i've figured it out. I was getting problems because the app is now installed on my second drive. i did this as i now have a ssd/hdd setup and the ssd is small but i've now moved it back to the ssd and it works again :)
They are both hfs+ by the way :)
steveyg777
The app must be installed on HFS+ file system volume (not NTFS/FAT/etc)
