1.4.2 - no Controls visible after system restart
On my 2012 Mac Mini version 6.2, running OS 10.8.5, I find that I have nothing in the "Control" column to input my temperatures for activation. Of course, 1.4.0 worked just fine on this same machine.
Macs Fan Control 1.4.1
Macmini6,2
CPU: Intel(R) Core(TM) i7-3615QM CPU @ 2.30GHz [105]
GPU: Intel HD Graphics 4000
Mac OS X 10.8.5
Exhaust-min{1800}curr{1806}max{5500}mode{2,TCXc,85,95}
TA0P () - 42.75, 42.75
TA0p (Ambient) - 42.75, 42.75
TA1P () - 45, 45
TA1p (Ambient 2) - 45, 45
TC0C () - 54, 54
TC0D () - 54.5, 54.5
TC0E () - 62.3789, 62.3789
TC0F () - 63.9102, 63.9102
TC0G () - 99, 99
TC0J () - 1.53125, 1.53125
TC0P () - 50.75, 50.75
TC0c (CPU Core 1) - 54, 54
TC0d (CPU Diode) - 54.5, 54.5
TC0p (CPU Proximity) - 50.75, 50.75
TC1C () - 54, 54
TC1c (CPU Core 2) - 54, 54
TC2C () - 54, 54
TC2c (CPU Core 3) - 54, 54
TC3C () - 54, 54
TC3c (CPU Core 4) - 54, 54
TCGC () - 53, 53
TCGc (GPU PECI) - 53, 53
TCPG () - 103, 103
TCSC () - 52, 52
TCSc () - 52, 52
TCTD () - -1, 255.73
TCXC () - 57.1875, 57.1875
TCXc (CPU PECI) - 57.1875, 57.1875
TCXr () - -1, 208.188
TH0A () - -1, 129
TH0B () - -1, 129
TH0C () - -1, 129
TH0F () - -1, 0
TH0O () - -1, 249
TH0X () - -1, 129
TH0a () - -1, 129
TH0b () - -1, 129
TH0c () - -1, 129
TH1A () - -1, 129
TH1B () - -1, 129
TH1C () - -1, 129
TH1F () - -1, 0
TH1O () - 9, 9
TH1X () - -1, 129
TH1a () - -1, 129
TH1b () - -1, 129
TH1c () - -1, 129
TI0P () - 50.625, 50.625
TI0p (Thunderbolt Proximity) - 50.625, 50.625
TI1P () - 47, 47
TI1p () - 47, 47
TM0P () - 50.875, 50.875
TM0S (Memory Slot) - 52.75, 52.75
TM0p (Memory Proximity) - 50.875, 50.875
TMBS () - -1, 129
TP0P () - 49.75, 49.75
TP0p () - 49.75, 49.75
TPCD (Platform Controller Hub Die) - 52, 52
TW0P () - 40.5, 40.5
TW0p (Airport Card) - 40.5, 40.5
Tp0C (PSMI Supply AC/DC Supply 1) - 49.8398, 49.8398
Ts0G () - 49, 49
Ts0S () - 34.4375, 34.4375
APPLE HDD HTS541010A9E662 - 36
Macmini6,2
Mac OS X 10.8.5
TA1P () - 45, 45
TC0C () - 54, 54
TC0G () - 99, 99
TC1C () - 54, 54
TC2C () - 54, 54
TC3C () - 54, 54
TCGC () - 53, 53
TCPG () - 103, 103
TCSC () - 52, 52
TCSc () - 52, 52
TH0A () - -1, 129
TH0B () - -1, 129
TH0C () - -1, 129
TH0F () - -1, 0
TH0O () - -1, 249
TH0X () - -1, 129
TH0a () - -1, 129
TH0b () - -1, 129
TH0c () - -1, 129
TH1A () - -1, 129
TH1B () - -1, 129
TH1C () - -1, 129
TH1F () - -1, 0
TH1O () - 9, 9
TH1X () - -1, 129
TH1a () - -1, 129
TH1b () - -1, 129
TH1c () - -1, 129
TI1P () - 47, 47
TI1p () - 47, 47
TMBS () - -1, 129
Ts0G () - 49, 49
- Screen Shot 2016-04-19 at 3.10.51 PM.png (68.76 KiB) Viewed 170130 times
Frank Lockwood
Mac Mini 6.2, 2.3 GHz. i7
Mac OS 10.8.5
Mac OS 10.8.5
Re: Update to 1.4.1 - no Controls available.
..., predictably, downloading the program from the website and using it to replace the one that was installed by the automatic update process fixed the issue, at least for now.
I never seem to have much luck with the automatic update process, as I always seem to have to re-download and reinstall. On the other hand, I prefer it this way, as I like to be in control of what gets installed and when, as opposed to having a pop-up appear unexpectedly.
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
fbl
It's related with the fact the fan control is set to sensor-based. Please write us if the problem appears again
The issue of the missing Controls reasserted itself today, until I re-sized the MFC window slightly. This was enough to position the (newly movable) divider between the left and right areas just enough that the Controls snapped back into visibility. This is on Mac OS 10.8.5.
Two steps forward, one step back, or is it the other way around? At any rate, all here is good, for the time being.
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
fbl
So the problem is connected with the devider now? Can you reproduce it by resizing window/devider ?
Every time I "Show Macs Fan Control" after restarting my machine, it opens with the Controls invisible. I tried to move the divider while it was in this state, but it won't move - my guess is that the default window width is too narrow to allow the divider to move.
Enlarging the whole window by dragging on the lower right corner - even just a little - results in the Controls becoming visible, and I can then move the divider back and forth. If I then re-adjust the window size back down to its narrowest, the Controls remain visible, but the divider can't be moved, as before. The Controls then remain visible every time I re-open the window, until I re-boot the machine, whereupon they are hidden once again.
I should mention that due to my vision requirements, I have set the Mac's Desktop View Options to have the fonts display at 16 points, which might be connected to the size of the font display within the MFC window. Also, within the MFC Preferences, I have the "Precise Display of Temperature when Possible" enabled, so all my temperatures are shown to a single decimal place.
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
fbl
I put an issue on that for 1.4.2, will improve that code. Thanks
One more thing: could you please make a screenshot with missing controls? Thanks.
PS. We rely on Qt UI framework by Digia, we update it regularly and thus have to fix some UI issues.
Normally the app should remember the previous window position and size. So you just make big enough for the next reboot.Every time I "Show Macs Fan Control" after restarting my machine, it opens with the Controls invisible.
We received the second report of this problem:( and I'm still not able to reproduce it
- Fehler macsfancontrol 1.4.2.0.png (85.24 KiB) Viewed 170074 times
That's got it. See attached. (First image is Dev. version, second is 1.4.2.)
Thanks very much.
Thanks very much.
- Dev Version Screen Shot.png (74.46 KiB) Viewed 170067 times
- V. 1.4.2 Screen Shot.png (70.04 KiB) Viewed 170067 times
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
fbl
Thanks for getting back in touch.
Please make sure it really works!
The other user who reported this problem claims that the dev build didn't solve it.
I'm afraid I have to agree with your other user. Things worked properly yesterday when I first installed the dev version, but today, it's back to its old behaviour of hiding the controls until I resize the window.
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
fbl
Here's the next build, please reproduce the issue once again.
When the controls are still NOT visible, please press the help ("?") button in the window, it will do some diagnostics and tests.
http://www.crystalidea.com/downloads/ma ... l_dev3.zip
thank you!
thank you!
I downloaded, installed and ran the dev build 3, and clicked on the "?" as you asked. How do I get the information it found, to you?
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
fbl
just tell me if the window says visible yes or no (for the control widget)
better start with build 4: http://www.crystalidea.com/downloads/ma ... l_dev4.zip
The Dev4 behaves strangely, but it does show the Controls column when it first is asked to appear following a computer restart. A small pop-up window appeared as well, with "visible: yes" in it. It then promptly quits entirely when asked to "Hide to menu bar".
Following a computer restart, pop-up windows appear unbidden, showing "visible: no" and another notice which disappeared too quickly for me to see. It did not automatically start or appear in the Menu bar. Perhaps you know all this already.
Bottom line, the window appears - when it appears - correctly. Following a reinstall of 1.4.2, its first appearance is also correct.
Following yet another computer restart, 1.4.2 had to be started manually, even though the Preference is for it to auto-start with the system. Predictably, 1.4.2 appeared with the Controls column missing but as before, a manual resizing of the window caused it to appear.
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
fbl
So the dev4 version was sterted after computer restart with "visible: no" ? (at least one time). "visible: no" means that controls are not visible
Now let's try build 5, hope it will work!
http://www.crystalidea.com/downloads/ma ... l_dev5.zip
I'm afraid that, following a computer re-start, dev5 comes up with no Controls visible, provided that prior to the re-start, it had been opened and the window sized to its narrowest allowed width, then closed.
Once opened, a small, manual widening of the window allows the Controls to peak through. Following subsequent re-sizing back down to the narrowest width, they continue to be visible, until the next computer re-start.
Frank Lockwood
Mac OS 10.8.5
Mac OS 10.8.5
Dev6: http://www.crystalidea.com/downloads/ma ... l_dev6.zip
fbl
When the controls are not visible in build 6, could you please press the "?" button and tell me "visible: yes" or "visible: now" message displayed.
fbl
