Update from 1.4.1 to 1.4.2 fails: "error extracting update"
IMPORTANT:
When you have version 1.4.1 installed, automatic update to 1.4.2 will fail because of the bug in the app.
Please update manually by downloading 1.4.2 from our website and replacing 1.4.1 in your /Applications folder.
Sorry for the inconvenience.
Screen Shot 2016-04-23 at 4.10.26 PM.png (24.94 KiB) Viewed 33933 times
IdleDove
Re: "Macs Fan Control damaged" after lasted update
Post by IdleDove »
Hi, thanks for your response... I downloaded it once again & it worked fine. Not sure what happened, but it is working now, so all's good. Thanks for your time.
mgoi
Post by mgoi »
Hi there Steven,
Thanks for a great app. Just to let you know that the automated update function does not work with the latest update.
See the error message below.
M
Screen Shot 2016-04-23 at 4.10.26 PM.png (24.94 KiB) Viewed 34042 times
macterryh
Auto Updater
Post by macterryh »
04/23/16 I Keep Getting A Pop Up To Update To Version # 1.4.2 But It Fails To Extract The File, & Quits !!!! :(
04/24/16 It Happened Again This A.M. !!!! :-(
phantom_fa
Post by phantom_fa »
I had same problem with latest update to 1.4.2.
Updating from within the app gave the 'error extracting update' on two different systems.
downloading from the website and manually installing worked fine.
Cheers
Mondrian
Update from 1.41 to 1.42 not occurring
Post by Mondrian »
I downloaded the update to Macs Fan Control 1.42. It downloads, but at the end returns a message which says "error extracting update". All previous updates have taken place without incident. I am using the latest version of OSX. Is there anything I need to do to extract the update properly?
Mondrian
Re: Auto Updater
Post by Mondrian »
I am experiencing the same issue.
stuzog
Re: Auto Updater
Post by stuzog »
Same here, OS X 10.11.4
fbl
Re: Update from 1.41 to 1.42 not occurring
Post by fbl »
Don't use the auto-updater function when it pops up (choose "Remind me Later"). Download the latest version from the website, then quit MacsFanControl and replace it with the newer version.
Frank Lockwood
Mac Mini 6.2, 2.3 GHz. i7
Mac OS 10.8.5
Re: Auto Updater
Don't use the auto-updater function when it pops up (choose "Remind me Later"). Download the latest version from the website, then quit MacsFanControl and replace it with the newer version please (just this time)
mgoi
Post by mgoi »
phantom_fa wrote:I had same problem with latest update to 1.4.2.
Cheers
Same for me. A fresh install worked fine.
