Uninstall Tool 3.5 Released
New: Uninstall Windows Store Apps (also in batch uninstall) on Windows 8 and later.
New: Startup manager now displays tasks that automatically start on user logon. You can also add a new scheduled task with Uninstall Tool
New: great user interface experience with HiDPI display modes (e.g. 150% or 200% on modern 4k, 5k displays)
New: Install Tracker now monitors file/folder rename operations to provide even more accurate and fundamental tracing. The driver (CisUtMonitor.sys) is updated!
New: Launch Windows Task scheduler from Tools->System Tools menu
New: 32-bit apps are now marked with "32-bit" mark when running on 64-bit Windows (may be turned off)
Many improvements, many bugs fixed (more details coming soon)
Download: http://www.crystalidea.com/downloads/un ... _setup.exe
Re: Uninstall Tool 3.5 Beta
Update! New: Startup manager now displays tasks that automatically start on user logon. You can also add a new scheduled task with Uninstall Tool
New build with a couple of bug fixes.
New build 5505 with crash fix (happened when listing certain startup tasks)
Re: Uninstall Tool 3.5 Released
New build 5507 with crash fix (happened on 32-bit version when clicking on "Don't show this again" checkbox in the popup window with recent programs)
New build 5508: fixed trial version dialog, minor improvements for Windows Tasks startup programs.
