The Procedure entry point GetSystemFirmwareTable could not b
The Procedure entry point GetSystemFirmwareTable could not be located in the dynamic link library Kernel32.dll this happens at the end of installation macbook pro 3,1 xp sp3 latest version of MFC when I start MFC it restarts the computer immediatly .... The older version works great.
Re: The Procedure entry point GetSystemFirmwareTable could not b
Now it says Unsupported Hardware Detected the program is able to run on Apple hardware only. It does not restart the computer like the previous attempt. Thanks for looking into this issue.
same message. unsuported hardware detected thanks
ohboyohboyohboy
Please try this build:
http://www.crystalidea.com/downloads/ma ... ev_283.exe
It will create c:\bios.dmp file, please send to us (attach as .zip)
this works so far. I have not fiddled with the settings yet though
ohboyohboyohboy
so it works now?
so it works now?
Yes it seems fine. I love this software . The weather here gets hot in the summer and when I use my macbook pro for heavy video I run the fans faster than the mac itself would without MFC. Without MFC it runs hotter than I like. Now I don't have to wait through the update request each time I start. I will do more testing and keep you posted. Thank you.
ohboyohboyohboy
Fixed in 1.4.3, closed.
