Fan Control Won't Speed Up the Fan
So my Mac gets so hot, and I try to increase the RPM on the fan but it won't budge, and stays at arround 2300 RPM. I notice however that if I go to the minimum, the fan will go down. Does anyone know why and/or how to fix it?
Re: Fan Control Won't Speed Up the Fan
Macs Fan Control 1.4.2
MacBookPro9,2
CPU: Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz [105]
GPU: Intel HD Graphics 4000
Mac OS X 10.11.1
Exhaust-min{2000}curr{2708}max{6200}mode{2,TC2C,70,78}
TA0P (Ambient) - 54.125, 54.125
TB0T (Battery Max) - 40.2969, 40.2969
TB1T (Battery Sensor 1) - 40.2969, 40.2969
TB2T (Battery Sensor 2) - 38.7969, 38.7969
TC0E () - 91.9336, 91.9336
TC0F () - 94.3438, 94.3438
TC0J () - 2.41016, 2.41016
TC0P (CPU Proximity) - 76.75, 76.75
TC1C (CPU Core 1) - 93, 93
TC2C (CPU Core 2) - 93, 93
TCGC (GPU PECI) - 95, 95
TCSA () - 88, 88
TCTD () - -1, 255.945
TCXC (CPU PECI) - 95.2031, 95.2031
TG1D () - 94.3438, 94.3438
TM0P (Memory Proximity) - 51.75, 51.75
TM0S (Memory Slot) - 68.3477, 68.3477
TPCD (Platform Controller Hub Die) - 80, 80
Th1H (Heatsink Proximity) - 60.75, 60.75
Ts0P (Palm Rest) - 38, 38
Ts0S () - 52.3242, 52.3242
APPLE HDD HTS545050A7E362 - 42
MacBookPro9,2
Mac OS X 10.11.1
TCSA () - 88, 88
- MacsFanControl1.png (77.28 KiB) Viewed 17256 times
I also tried adjusting it by 1000 RPM and still nothing happened.
Ilmc57
Does it ever speed up up to max when Control is set to Auto ? (e.g. when playing games)
No it doesn't.
At most I get ~3600RPMs
Ilmc57
Looks like the fan is physically broken. Did you try on Windows (Boot camp)?
No, and also I should point out whenever I log back into my computer it listens for a few minutes, but then goes back to how it was.
