Highlighting applications in the list
pierrot_idf
Without having recently installed applications, I see regulary ten to twelve highlighting applications in the list.
What is the exact installation date of those? (can be viewed in the left panel)
pierrot_idf
today (if the problem appears today)
Can you post here a screenshot?
pierrot_idf
If you quit the app and start Uninstall Tool again this highlighted apps should disappear.
You could also try our development version, probably this problem is already fixed there:
http://www.crystalidea.com/downloads/un ... up_dev.exe
pierrot_idf
OK; I try your development version and I'll you know if this problem appears again.
Thank you for your help
pierrot_idf
Sorry but the problem is still present
Looks like we fixed it in Uninstall Tool 3.5.2 beta:
Do you have Windows 10 ?
pierrot_idf
Yes I have Windows 10 version 1607
I reproduced this "bug", it's actually caused by incorrect behavior of Windows 10 (it changed dates of uninstall registry keys from time to time). So it should be fine now in 3.5.2 beta.
