New problem as of 3 days ago
modelamac
Post by modelamac »
I an running Macs Fan Control 1.4.3.0, and until 3 days ago all was well. I started getting this update notice at login. I would select continue, and the Macs Fan Control window would appear.
Sensor based.png (87.72 KiB) Viewed 11003 times
My Mac.png (115.83 KiB) Viewed 11003 times
Constant speed.png (66.74 KiB) Viewed 11003 times
Bottom line: Macs Fan Control is no longer working at all, and I can't alter any settings in it to make it work. I have been running the macOS Sierra public beta since it was available with no problems. Please note that the same problem exists in El Capitan on my iMac.
Please update manually to version 1.4.4, this issue is fixed
modelamac
Post by modelamac »
Yes. I used App Cleaner to remove the existing version. The built-in update process is not working. I went to your website and downloaded the latest version and now all is well again.
Thank you.
