Macbook 2015
nitefrog
Macbook 2015
Post by nitefrog »
I've been on call with Apple support to see if this is a macbook issue or a bug int he Macs Fan app. For some reason the app is only showing 3/4 CPU's. CPU 1 is missing but 2,3,4 al show. I have never seen this before. I am running OS X 10.11.6 (15G1212).
Please advise as I am not sure if this is an issue with the MAC or a glitch in the software.
MacBook spec in case you need them.
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro11,5
Processor Name: Intel Core i7
Processor Speed: 2.5 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 16 GB
Boot ROM Version: MBP114.0172.B09
Screen Shots as requested
Full Screen
Close Up
Screenshot 2016-12-29 01.15.02.png (101.53 KiB) Viewed 13207 times
Config Info
Macs Fan Control 1.4.4
MacBookPro11,5
CPU: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz [100]
GPU: AMD Radeon R9 M370X, Intel Iris Pro
Mac OS X 10.11.6
Left side-min{2160}curr{2165}max{6156}mode{2,TC1C,66,73}
Right side-min{2000}curr{2002}max{5700}mode{2,TC3C,60,71}
TB0T (Battery Max) - 33.0977, 33.0977
TB1T (Battery Sensor 1) - 33.0977, 33.0977
TB2T (Battery Sensor 2) - 31.8984, 31.8984
TBXT () - 33.0977, 33.0977
TC0E () - 55.4961, 55.4961
TC0F () - 56.7031, 56.7031
TC0P (CPU Proximity) - 48.25, 48.25
TC1C (CPU Core 2) - 50, 50
TC1F () - 53.0547, 53.0547
TC1f () - 53.0547, 53.0547
TC2C (CPU Core 3) - 49, 49
TC3C (CPU Core 4) - 51, 51
TC4C () - 50, 50
TCGC (GPU PECI) - 51, 51
TCMc () - -1, 0
TCSA () - 49, 49
TCTD () - -1, 255.914
TCXC (CPU PECI) - 51.9531, 51.9531
TCXM () - 51.9844, 51.9844
TCXP () - 52.4219, 52.4219
TG0D (GPU Diode) - 35, 35
TG0F () - 38.4688, 38.4688
TG0P (GPU Proximity) - 47.75, 47.75
TG1D () - -1, 129
TH0A () - 39.625, 39.625
TH0B () - 39.625, 39.625
TH0C () - 37.625, 37.625
TH0F () - -1, 209.871
TH0R () - -1, 209.625
TH0V () - 40.918, 40.918
TH0a () - 39.625, 39.625
TH0b () - 39.625, 39.625
TH0c () - 37.625, 37.625
TH0x () - -1, 129
TM0P (Memory Proximity) - 47.125, 47.125
TM0S (Memory Slot) - 46.9492, 46.9492
TP0P () - 47.5, 47.5
TPCD (Platform Controller Hub Die) - 52, 52
TW0P (Airport Card) - 44.1875, 44.1875
Ta0P () - 35.875, 35.875
TaSP () - 35.8633, 35.8633
Th1H (Heatsink Proximity) - 44.375, 44.375
Th2H () - 44.25, 44.25
Ts0P (Palm Rest) - 32.5625, 32.5625
Ts0S () - 39.668, 39.668
Ts1P () - 32, 32
Ts1S () - 40.4883, 40.4883
APPLE SSD SM0512G - 39.625
Kindest Regards, Kevin
Re: Macbook 2015
nitefrog
Re: Macbook 2015
Post by nitefrog »
Just updated as you requested.
Kevin
Re: Macbook 2015
Thanks, fixed in version 1.4.5 (Will be released in 1-2 days)
