Been running the previous version absolutely fine on OS 10.11.6, multiple users on iMac. Logging out presented no problems.
Installed the 1.4.6 update today and now logging out of a user sets the fans to max.
Help!
1.4.6 , fans max out on logout, multiple users
Lena_Pfeffer
Re: 1.4.6 update kills system startup. fans max out.
I have the same problem!
iMac, OS 10.10.5, multiple users.
Which machines are you running? Tech specs from the Preferences dialog, please.
Lena_Pfeffer
Re: 1.4.6 , fans max out on logout, multiple users
I returned to the previous version today to avoid the problem for now. I have the German version, do you mean the following part?
Macs Fan Control 1.4.4
iMac11,2
CPU: Intel(R) Core(TM) i3 CPU 550 @ 3.20GHz [100]
GPU: ATI Radeon HD 5670
Mac OS X 10.10.5
Thanks!
iMac11,2
Mac OS X 10.10.5
Thanks!
Please try this test version of the app:
https://www.crystalidea.com/downloads/m ... ol_dev.zip
Lena_Pfeffer
I tried to use the test version, but the problem still appears. :/
Please enable log in preferences/diagnostics, restart the app, then logout, login again, and post here the .log file from your desktop.
Lena_Pfeffer
Here you are!
- MacsFanControl.log
- (3.85 KiB) Downloaded 1271 times
Thanks for the log, please re-download the test build, should work now!
Lena_Pfeffer
It does! Thank you very much for the quick help!
