Uninstall Tool 3.5.2 Released
13 Jan 2017, 11:48
Uninstall Tool 3.5.2 Build 5552 Released !
- Uninstall Tool now remembers (apps list) sorting parameters between its launches
- Uninstall Wizard leftovers scan speed is significantly increased (really noticeable, specially on Windows 10)
- Size calculation algorithm now includes data folders (e.g. in AppData, MyDocuments and others)
- Increased list item height from 32 to 40 px for better readability
- Install Tracker now supports .msp files to append traced data
- The app now works on older CPUs without SSE2 support (Windows XP 32-bit)
- Fixed Install Tracker now works in Windows 10 with Secure Boot turned on in BIOS
- Fixed waiting for uninstall process(es) for some apps
- Fixed delayed removal (after restart) of empty folders in Uninstall Wizard
- Fixed calculating of apps installation date in Windows 10
- Fixed displaying of apps updates (sub-items)
- Fixed algorithm of initial sorting of programs by occupied size
- Fixed incorrect detection of apps as recent
- Misc fixes and improvements
- Translations update
Download
sngsnick
Re: Uninstall Tool 3.5.2 Released
13 Jan 2017, 15:53
В этой версии не работает ничего из того, что связано с автозапуском. Запущенные программы отмечены как не запущенные. Добавить в автозапуск тоже ничего нельзя.
13 Jan 2017, 16:01
Working on the urgent fix right away.
13 Jan 2017, 16:33
Build 5553 - fixed startup manager. Sorry for that regression bug.
25 Jan 2017, 15:49
Build 5554 - new digital signature, fixed crash on old CPUs without SSE2
07 Feb 2017, 07:31
Build 5555 - fixed .msp files support in Install Tracker
08 Feb 2017, 20:30
Build 5556 - fixed support of old CPUs without SSE2
