fer
getting rid of AnyToISO icons OSX
03 Apr 2017, 18:07
Dear Crystalidea,
I needed your software at a friends computer so I installed a trial, after the installation all the icons for .rar and .r00 etc changed to anytoiso icons... removing the software didn't change anything and also the files default setting is now "the unarchiver". I would like it if the icons could also change back. (the information windows shows the correct icons (unarchiver files), the desktop and Finder windows do not
Did I not remove the software properly? how do I remove such icons from the system?
Re: getting rid of AnyToISO icons OSX
03 Apr 2017, 19:57
I think you need to simply reboot the computer.
If it won't help,
http://apple.stackexchange.com/question ... -in-finder
Users browsing this forum: No registered users and 0 guests
