Hi, I'm not being able to control my fan at all with MFC. Ether I set a contact rpm or sensor based, it won't respond to the commands. I've tried resetting SMC, and even restoring my Mac. I did some research on this forum and couldn't find much info about this topic, does anyone have any suggestion?
Mac mini 2011 server.
2 256gb Samsung SSD that doesn't show any temperature on MFC control panel
I've run apples hardware test, fan motor it's failing, bought another one and it finished with the same result..
Mac mini 2011 not responding to any MFC Command
Re: Mac mini 2011 not responding to any MFC Command
Last reboot log:
INFO 2017-04-19T23:35:52.771 MacFanControl/app.cpp @ 195 "Macs Fan Control 1.4.7"
INFO 2017-04-19T23:35:52.771 MacFanControl/app.cpp @ 196 "macOS 10.12.4"
INFO 2017-04-19T23:35:52.772 MacFanControl/app.cpp @ 197 "Macmini5,3"
INFO 2017-04-19T23:35:52.772 MacFanControl/app.cpp @ 198 "Intel(R) Core(TM) i7-2635QM CPU @ 2.00GHz"
INFO 2017-04-19T23:35:52.772 MacFanControl/app.cpp @ 199 "Qt 5.6.2"
INFO 2017-04-19T23:35:53.714 MacFanControl/core/FanControl.cpp @ 268 "QFanControl::InitialLoadThread"
INFO 2017-04-19T23:35:53.714 MacFanControl/core/FanControl.cpp @ 282 "QFanControl::InitialLoadThread - LoadCachedFansAndTempSensors"
INFO 2017-04-19T23:35:53.714 MacFanControl/core/FanControl.cpp @ 287 "QFanControl::InitialLoadThread - smc_get_fans_control_mode"
INFO 2017-04-19T23:35:53.716 MacFanControl/core/FanControl.cpp @ 79 "Fan " 0 ": manual"
INFO 2017-04-19T23:35:53.716 MacFanControl/core/FanControl.cpp @ 291 "QFanControl::InitialLoadThread - QTempSensorSmart::loadAvailableSensors"
INFO 2017-04-19T23:35:53.723 MacFanControl/core/FanControl.cpp @ 295 "QFanControl::InitialLoadThread - FilterSupportedTempSensors"
INFO 2017-04-19T23:35:53.756 MacFanControl/core/FanControl.cpp @ 308 "QFanControl::InitialLoadThread: number of supported SMC sensors: 16"
INFO 2017-04-19T23:35:53.756 MacFanControl/core/FanControl.cpp @ 309 "QFanControl::InitialLoadThread: number of supported SMART sensors: 2"
INFO 2017-04-19T23:35:53.838 MacFanControl/core/smc.cpp @ 334 Set fans mode 1
INFO 2017-04-19T23:35:54.843 MacFanControl/core/SensorControl.cpp @ 109 "Exhaust: HALF INCREASE ON"
INFO 2017-04-19T23:35:54.843 MacFanControl/core/SensorControl.cpp @ 114 "Exhaust: Tendency is set to TendencyIncrease, Temperature 48, RPM=6739"
INFO 2017-04-19T23:35:54.843 MacFanControl/core/SensorControl.cpp @ 393 "Exhaust: Setting fan speed to" 2301
INFO 2017-04-19T23:35:54.908 MacFanControl/core/smc.cpp @ 334 Set fans mode 1
INFO 2017-04-19T23:35:55.975 MacFanControl/core/SensorControl.cpp @ 159 "Exhaust: Temperature DECREASED to 47"
INFO 2017-04-19T23:35:55.975 MacFanControl/core/SensorControl.cpp @ 183 "Exhaust: Ignoring temperature change"
INFO 2017-04-19T23:35:55.975 MacFanControl/core/SensorControl.cpp @ 208 "Exhaust: Tendency is set to TendencyIncrease"
INFO 2017-04-19T23:35:55.975 MacFanControl/core/SensorControl.cpp @ 393 "Exhaust: Setting fan speed to" 2303
INFO 2017-04-19T23:35:57.040 MacFanControl/core/SensorControl.cpp @ 159 "Exhaust: Temperature DECREASED to 47"
INFO 2017-04-19T23:35:57.040 MacFanControl/core/SensorControl.cpp @ 183 "Exhaust: Ignoring temperature change"
INFO 2017-04-19T23:35:57.040 MacFanControl/core/SensorControl.cpp @ 208 "Exhaust: Tendency is set to TendencyIncrease"
INFO 2017-04-19T23:35:57.040 MacFanControl/core/SensorControl.cpp @ 393 "Exhaust: Setting fan speed to" 2305
INFO 2017-04-19T23:35:58.106 MacFanControl/core/SensorControl.cpp @ 393 "Exhaust: Setting fan speed to" 2300
INFO 2017-04-19T23:35:59.172 MacFanControl/core/SensorControl.cpp @ 109 "Exhaust: HALF INCREASE ON"
INFO 2017-04-19T23:35:59.172 MacFanControl/core/SensorControl.cpp @ 114 "Exhaust: Tendency is set to TendencyIncrease, Temperature 48, RPM=6739"
INFO 2017-04-19T23:35:59.172 MacFanControl/core/SensorControl.cpp @ 393 "Exhaust: Setting fan speed to" 2301
INFO 2017-04-19T23:36:00.238 MacFanControl/core/SensorControl.cpp @ 393 "Exhaust: Setting fan speed to" 2302
INFO 2017-04-19T23:36:01.307 MacFanControl/core/SensorControl.cpp @ 393 "Exhaust: Setting fan speed to" 2303
INFO 2017-04-19T23:36:01.707 MacFanControl/core/smc.cpp @ 334 Set fans mode 1
- Screen Shot 2017-04-19 at 11.31.34 PM.png (81.56 KiB) Viewed 10398 times
Run the Apple Hardware Test one more time.
If MFC is not able to change RPM, most likely because of some hardware failure
