Sleep walking running:
When my MacMini (2009) sleeps (shhh....) the fan is quietly running in the background.
I don't think this was the case before I used your app [I'm really grateful for it, by the way - thanks!].
I wonder if this is normal ... I'm concerned that the bearings will wear out if it's on all the time.
Thank you
John
Fan running during sleep.
Re: Fan running during sleep.
What are your MFC settings?
Sorry Steven - I forgot to do that!
- Screen Shot 2017-05-08 at 09.39.40.png (52.86 KiB) Viewed 13209 times
- Screen Shot 2017-05-08 at 09.38.55.png (57.95 KiB) Viewed 13209 times
- Screen Shot 2017-05-08 at 09.38.16.png (56.61 KiB) Viewed 13209 times
Please
1. Enable log
2. Put the computer into the sleep mode
3. Wake up after a minute
4. Send us the log please.
1. Enable log
How's this [I only paste the last bit, otherwise there are too many characters.
... set min rpm for the Master fan"
INFO 2017-05-10T09:31:33.950 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:33.950 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:35.016 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:35.016 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:36.082 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:36.083 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:37.150 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:37.150 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:38.218 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:38.218 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:39.286 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:39.286 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:40.353 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:40.353 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:41.420 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:41.420 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:31:42.486 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:31:42.486 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:32:18.388 MacFanControl/core/FanControl.cpp @ 569 "ControlFanSpeedThread: sleep mode, reset all fans"
INFO 2017-05-10T09:32:18.388 MacFanControl/core/FanControl.cpp @ 581 "ControlFanSpeedThread: set min rpm for the Master fan"
INFO 2017-05-10T09:32:18.452 MacFanControl/core/smc.cpp @ 334 Set fans mode 1
INFO 2017-05-10T09:32:19.060 MacFanControl/core/FanControl.cpp @ 770 "slotWakeUp"
INFO 2017-05-10T09:32:19.516 MacFanControl/core/SensorControl.cpp @ 393 "Master: Setting fan speed to" 1000
WARN 2017-05-10T09:32:24.846 MacFanControl/core/smc.cpp @ 376 "smc_get_temp - skipping sensor Tm0P with value of 128"
INFO 2017-05-10T09:32:50.665 MacFanControl/core/smc.cpp @ 334 Set fans mode 1
