too few cores
pacarts
too few cores
Post by pacarts »
I have an iMac 11.3 27" quad i7, 2.8ghz. After an ssd install, I installed MFC and discovered only 2 cores were listed. Is this normal?
pacarts
Re: too few cores
Post by pacarts »
Correction: 2.93 quad i7
Screenshot 2017-11-12 09.52.28.png (90.61 KiB) Viewed 351845 times
Re: too few cores
Yes, this is normal. Don't worry
bguzik
Re: too few cores
Post by bguzik »
I have the same issue on my i7 Quad-Core iMac 11,1.   Only two cores show up, but I am confirmed running 8 threads over 4 cores.
Intel(R) Core(TM) i7 CPU         860  @ 2.80GHz
iMac11,1
ctl_id: 0x10 for ctl_name: crystalidea.macsfancontrol.kext
TjMax T: 99
[img]blob:https://forums.crystalidea.com/591c0e66 ... b30b5978c1[/img]
[img]blob:https://forums.crystalidea.com/5f364b35 ... 9830779ce1[/img]
Re: too few cores
Please post technical info from the Preferences dialog
bguzik
Re: too few cores
Post by bguzik »
Macs Fan Control 1.4.9
iMac11,1
CPU: Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz [100]
GPU: ATI Radeon HD 4850
macOS 10.12.6
ODD-min{1000}curr{994}max{3800}mode{0}
HDD-min{1100}curr{1092}max{5500}mode{0}
CPU-min{940}curr{948}max{2100}mode{0}
TA0P () - 22.3242, 22.3242
TA0V () - 22.3242, 22.3242
TA0p (Ambient) - 27.75, 27.75
TA1v () - 27.3672, 27.3672
TC0C (CPU Core 1) - 88.875, 88.875
TC0D () - -1, 129
TC0H (CPU Heatsink) - 66.125, 66.125
TC0P () - -1, 129
TC1C (CPU Core 2) - 88, 88
TG0D (GPU Diode) - 69.75, 69.75
TG0H (GPU Heatsink) - 68.5, 68.5
TG0p (GPU Proximity) - 69, 69
TH0O () - 3, 3
TH1O () - 3, 3
TL0P () - 43.6875, 43.6875
TL0V () - 38.6875, 38.6875
TL0p (LCD proximity) - 57, 57
TL1V () - 39.3242, 39.3242
TL2V () - 44.7031, 44.7031
TLAV () - 44.7031, 44.7031
TLBV () - 40.5781, 40.5781
TLCV () - 38.6875, 38.6875
TMCD () - -1, 0
TO0P () - 42.625, 42.625
TO0p (Optical Drive) - 43.625, 43.625
TPCD (Platform Controller Hub Die) - 61, 61
TS0V () - 51.1367, 51.1367
TS2P () - 44.125, 44.125
TS2V () - 42.3594, 42.3594
TS2p () - 44.125, 44.125
Tm0P () - 56.375, 56.375
Tm0p () - 56.375, 56.375
Tp1P () - 68.375, 68.375
Tp2H () - 92.125, 92.125
Tp3H (PSU Primary) - 71.75, 71.75
Samsung SSD 850 PRO 1TB - 65
Re: too few cores
The SMC gives only only on 2 cores. Using another API (Intel) it's possible to get extended information, but we're not planning this at the moment.
