Incorrect fan readings on the new iMacPro
pascalmarquis
Post by pascalmarquis »
Hello, I used this app on my old iMac and mac book air and it's awesome.
But since I have my new iMac Pro, I have weird with the fan and I'm unable to control anything.
The app show for both of my fans a minimum speed of 32 and maximum of 16.
And the speed of the fans varies between 2000 and 16 000 RPM.
Which is not the case since I think I would ear them if they were running at 16k.
Can you please help me?
This is the diagnostc :
Macs Fan Control 1.4.9
iMacPro1,1
CPU: Intel(R) Xeon(R) W-2150B CPU @ 3.00GHz [100]
GPU: Radeon Pro Vega 64
macOS 10.13.2
Fan 0-min{32}curr{13595}max{16}mode{0}
Fan 1-min{32}curr{266}max{16}mode{0}
TA0P () - 7, 7
TA0V () - 20.918, 20.918
TA0p (Ambient) - 27, 27
TC0E () - -1, 195.203
TC0F () - -1, 197.254
TC0J () - 2.05078, 2.05078
TC0P () - 36.5, 36.5
TC0T () - 0.21875, 0.21875
TC0c (CPU Core 1) - 39, 39
TC0p (CPU Proximity) - 36.5, 36.5
TC1P () - 38.0625, 38.0625
TC1c (CPU Core 2) - 38, 38
TC1p () - 38.0625, 38.0625
TC2P () - 39.1875, 39.1875
TC2c (CPU Core 3) - 37, 37
TC2p () - 39.1875, 39.1875
TC3c (CPU Core 4) - 38, 38
TC4c () - 37, 37
TC5c () - 36, 36
TC6c () - 36, 36
TC7c () - 38, 38
TC8c () - 37, 37
TC9c () - 36, 36
TCS0 () - 34, 34
TCS1 () - 35, 35
TCS2 () - 37, 37
TCS3 () - 36, 36
TCXR () - -1, 194.547
TCXc (CPU PECI) - 38.5469, 38.5469
TCXr () - -1, 194.547
TG0D () - 36, 36
TG0E () - 36.4844, 36.4844
TG0F () - 36.8906, 36.8906
TG0J () - 0.40625, 0.40625
TG0T () - 0.0234375, 0.0234375
TG0d (GPU Diode) - 36, 36
TG1D () - 36, 36
TG1E () - 36.0039, 36.0039
TG1F () - 36.0938, 36.0938
TG1J () - 0.0898438, 0.0898438
TG1P () - 31.5, 31.5
TG1T () - -1, 0
TG1d () - 36, 36
TG1p () - 31.5, 31.5
TG2P () - 33.1875, 33.1875
TG2d () - 43, 43
TG2p () - 33.1875, 33.1875
TG3P () - 31.625, 31.625
TG3d () - 39.3125, 39.3125
TG3p () - 31.625, 31.625
TH0A () - 29.3281, 29.3281
TH0B () - 29.3672, 29.3672
TH0F () - 34.9648, 34.9648
TH0X () - 34.9102, 34.9102
TH0a () - 29.3281, 29.3281
TH0b () - 29.3672, 29.3672
TH1A () - 34.9102, 34.9102
TH1B () - 34.9102, 34.9102
TH1a () - 34.9102, 34.9102
TH1b () - 34.9102, 34.9102
TI0P () - 37.9375, 37.9375
TI0d () - 37.8125, 37.8125
TI0p (Thunderbolt Proximity) - 37.9375, 37.9375
TI1P () - 35.3125, 35.3125
TI1d () - 31.75, 31.75
TI1p () - 35.3125, 35.3125
TI2d () - 50.25, 50.25
TL0P () - 34.0625, 34.0625
TL0V () - 31.0781, 31.0781
TL0p (LCD proximity) - 34.0625, 34.0625
TL1P () - 34.9375, 34.9375
TL1V () - 31.6719, 31.6719
TL1p () - 34.9375, 34.9375
TL1v () - 31.6562, 31.6562
TM0P () - 34.5, 34.5
TM0V () - 41.3633, 41.3633
TM0p (Memory Proximity) - 34.5, 34.5
TM1P () - 34.6875, 34.6875
TM1p () - 34.6875, 34.6875
TM2P () - 38.5625, 38.5625
TM2p () - 38.5625, 38.5625
TM3P () - 36.8125, 36.8125
TM3p () - 36.8125, 36.8125
TM4a () - 41.3633, 41.3633
TM4b () - 45.3633, 45.3633
TMXP () - 38.5625, 38.5625
TPCD (Platform Controller Hub Die) - 43, 43
TS0V () - 30.7969, 30.7969
Tb0P () - 40.25, 40.25
Tb0p () - 40.25, 40.25
Tm0P () - 35.4375, 35.4375
Tm0p () - 35.4375, 35.4375
Tm1P () - 33.9375, 33.9375
Tm1p () - 33.9375, 33.9375
Tm2P () - 32.25, 32.25
Tm2p () - 32.25, 32.25
Tm3P () - 33.75, 33.75
Tm3p () - 33.75, 33.75
Tp2F () - 38.3984, 38.3984
Tp2H () - 38.375, 38.375
Tp2h () - 38.375, 38.375
SSD A - 29.4414
Thank you!
Pascal :D
Screen Shot 2018-01-01 at 8.53.49 PM.jpg (61.8 KiB) Viewed 362054 times
Re: Weird Fan Speed Stats
Looks like the app doesn't work correctly on the new iMacPro.
Unfortunately I don't have this mac to test.
Please download this test version:
https://www.crystalidea.com/downloads/m ... l_beta.zip
enable log file in Preferences, restart the app, and send us the log file located on your desktop.
Thank you.
pascalmarquis
Re: Incorrect fan readings on the new iMacPro
Thank you for your quick answer Steven,
I have the same problem with the new application.
Here is the log.
Not that iStats pro also show me weird info.
like 167 000 000 RPM and -284 000 000 RPM.
Thanks again!
Pascal
MacsFanControl.log
(113.26 KiB) Downloaded 14595 times
Hi and thank you for the testing!
Looks like it's the first mac model in more than 10 years when Apple changed SMC (https://en.wikipedia.org/wiki/System_Ma ... Controller) specs.
They use new 'flt' type for smc key where the known 'fp78' was expected.
I couldn't fine anything related to this change in Google, I'm afraid we need to wait till someone does some reverse engineering and sheds some light on the issue.
Apple has never published any public info about SMC. I'll keep everyone informed on the progress in this topic.
Thanks again.
pascalmarquis
All right,
Thank you for your time, Steven.
I hope to have news from you soon.
No pressure here but your app is kinda of an essential on Mac system since Apple is just so stupid and let their computer burn.
Thanks again!
Pascal
pascalmarquis
I've just spoken with Apple care.
When I talk to the guy, he tells me that 95 C is very warm and ask me to do an SMC reset.
So it seems that the iMacPro is still using SMC.
He makes me boot up in safe mode, shut down, hold the power button for 8 seconds (which is the SMC reset) and finally reboot.
I will test in next days if the temperature is cooler.
But still, I can't control the fan speed with your awesome application.
Thanks again!
Pascal
pascalmarquis
Hello Steven,
I've seen that you post an update on the forum but it's not there anymore.
My iMac pro was in a box since the last post since I was moving my office.
Now I'm back and ready to test the update when you want.
Thank you!
Pascal
