xcbx
Extract Question
16 Jan 2018, 17:43
1)  Can AnyToISO extract mac high sierra install/update DMGs + PKGs ?
No sign up or dev account needed to download the newer mac system DMGs directly from apple.
http://appldnld.apple.com/macos/091-58875--20180109-7052760C-F266-11E7-8A10-F41F3B84D6FD/macOSUpd10.13.2Supplemental.dmg
Re: Extract Question
17 Jan 2018, 08:19
Thank you for your feedback. Marked as feature request, in progress:
https://github.com/crystalidea/anytoiso/issues/2
xcbx
18 Jan 2018, 07:02
Thanks! Fast -
The payloads inside the pkgs dont dump to raw file format. Cant get to the system files.
 7zip was able to open the older mac os payloads.
Update:
I managed to extract but had to use unix (pbzx  'cpio' ).
https://gist.github.com/Lekensteyn/6e0840e77bc9bd013f57
parse_pbzx.py Payload | cpio -I
Is this something that can be added in ?
18 Jan 2018, 15:51
I've updated the app, now it can extract Payload 'pbzx' inside such images
https://www.crystalidea.com/downloads/a ... p_beta.exe
One just has to add .pbzx extension to the Payload file
https://github.com/crystalidea/anytoiso/issues/4
xcbx
19 Jan 2018, 11:01
Using forum is more interactive. Nice layout also :D
Thanks again, its well appreciated. Super cool!
19 Jan 2018, 11:04
No, I believe it's far from DMG images.
xcbx
19 Jan 2018, 11:30
 Ok  - Np
Users browsing this forum: No registered users and 0 guests
