Command Line on Mac
Command Line on Mac
How do I access the command line version of AnyToISO on a Mac? Your tutorial does not indicate where it is installed. Thx.
Re: Command Line on Mac
SigMan
Have you tried?
/Applications/AnyToISO.app/Contents/MacOS/AnyToISO
Have you tried?
Yes. I tried to wrap the bin directory in my home folder:
/Applications/AnyToISO.app/Contents/MacOS/AnyToISO ./bin ./bin.iso /label: /fs:
No errors or anything, it just doesn't produce the .iso file.
Also, I tried: /Applications/AnyToISO.app/Contents/MacOS/AnyToISO /help
No error but no response.
SigMan
That's how it works:
(creates an image in the home directory of the current user)
PS. There's a lack of output on mac, but this will be improved soon.
/Applications/AnyToISO.app/Contents/MacOS/AnyToISO /fromdir /Volumes/SECURE/test ~/test_image.iso /label:MY_IMAGE /fs:udfPS. There's a lack of output on mac, but this will be improved soon.
sudo ln -s /Applications/AnyToISO.app/Contents/MacOS/AnyToISO /usr/bin/any2iso Code: Select all
any2iso /fromdir /Volumes/SECURE/test ~/test_image.iso /label:MY_IMAGE /fs:udf- Steven
jackie
