Problem with FastStone Image Viewer using InstallTracker
Silent Rain
Re: The problem with FastStone Image Viewer using InstallTracker
Silent Rain
Please tell us what problem do you experience, what is Uninstall Tool full version (including build number)? Windows version? 32 or 64 bit?
I personally installed this program with Install Tracker without any issue.
Silent Rain
Re: Problem with FastStone Image Viewer using InstallTracker
After installation is complete (FastStone Image Viewer) technology Install Tracker has continued to work and recorded the unnecessary processes of Opera, which is run itself automatically!Steven wrote:Silent Rain
Please tell us what problem do you experience...
Uninstall Tool 3.0.0.5210Steven wrote:...what is Uninstall Tool full version (including build number)?
Windows 7 Home Premium (SP1) x64Steven wrote:...Windows version? 32 or 64 bit?
Silent Rain
thank you, this will be fixed in next Uninstall Tool versions (this is opera-only related issue)
Silent Rain
Ok, I'll wait for the new versionSteven wrote:Silent Rain
Silent Rain
It will not be very soon
This fix requires driver rebuild and many users will have to reboot their PC.
Silent Rain
It doesn't matter! The main thing that you've fixed this bug
