Feature - query
Nandakumar
Feature - query
I have bought this uninstaller tool. Whether it has capability to remove traces from registry for all softwares that are not showing in add/remove program in a single click. Whether any scheduling option available to do cleanup?
Re: Feature - query
You can use Install Tracker to create custom entries (that can be not visible in ADd/Remove program).
