Speedyfox and Firefox paths
Top popular freeware SpeedyFox
berra
Post by berra »
Hello!
I use "SpeedyFox" to optimize Firefox and it works great with one exception.
My paths in win7 is:
C:/user/xxxx/appdata/Roaming/Mozilla/Firefox/Profiles/xxxxxxxx.default/
C:/user/xxxx/appdata/Local/Mozilla/Firefox/Profiles/xxxxxxxx.default/urlclassifier3.sqlite
The first path is ok. The other path to "urlclassifier3.sqlite" optimizes SpeedyFox not.
I use SpeedyFox 1.6 to optimize "urlclassifier3.sqlite", then I use the new SpeedyFox for the first path.
Is there any way to SpeedyFox 2.0.3 will find both paths?
Re: Speedyfox and Firefox paths
Firefox path is located at '%APPDATA%\Mozilla\Firefox\Profiles'
More info at:
http://kb.mozillazine.org/Profile_folder_-_Firefox
berra
Post by berra »
Why have you changed in the new version so I can not choose which way I'm trying to optimize? Have you changed it because there are other programs that also have "sqlite" files?
We didn't change this in 2.0 version.
You can manually select your profile folder if it's located in non-standard place.
berra
Post by berra »
Hello!
No, I can not choose which path I want to be optimized. I want to optimize "urlclassifier3.sqlite". I show instead with screenshot.
First path is ok:
Second path only have these files and folders:
/jumpListCache/
/OfflineCache/
/safebrowsing/
/startupCache/
/urlclassifier.pset
1. A screenshot of "SpeedyFox". The program can not find my second path.
2. A screenshot of the "BrowserBackup". This program will find my path.
The second screenshot of BrowserBackup displays the same selected profile as in Speedyfox, located at appdata/Roaming
Anyway, can you please post the list of files at the profile (which is not supported) folder?
berra
Post by berra »
Ok! Here you have the file paths!
C:\users\Privat\Appdata\Local\Mozilla\Firefox\Profiles\xxxxxxxx.default\OfflineCache\index.sqlite
C:\users\Privat\Appdata\Local\Mozilla\Firefox\Profiles\xxxxxxxx.default\urlclassifier3.sqlite
So are there only 2 files inside 'C:\users\Privat\Appdata\Local\Mozilla\Firefox\Profiles\xxxxxxxx.default' ?
berra
Post by berra »
Sorry!
C:\users\Privat\Appdata\Local\Mozilla\Firefox\Profiles\xxxxxxxx.default\urlclassifier.pset
C:\users\Privat\Appdata\Local\Mozilla\Firefox\Profiles\xxxxxxxx.default\jumpListCache\xxxxxxx.ico
A lots of ".ico" Cached files
Look at Screenshot:
C:\users\Privat\Appdata\Local\Mozilla\Firefox\Profiles\xxxxxxxx.default\safebrowsing\
C:\users\Privat\Appdata\Local\Mozilla\Firefox\Profiles\xxxxxxxx.default\startupCache\startupCache.4.little
