how to put the uninstall tool on my flash drive.
i have purchased the portable version. and installed on my computer
i used it to remove RUBotted....worked WELL!!!
when i get to bro's with my flash drive i need it to work the first time [80 miles round trip]
so hoping to get directions. thanks for the awsome product!
and thanks to kim comando for the tip!
TIA
need a simple how-to/what file to send to flash drive
Re: need a simple how-to/what file to send to flash drive
i've looked at the 'help' files.faq. it's very light on info on how to get started.
few more questions.....
do i install the portable version on my brother's 'puter. or does it run from the flash drive.
can i keep it installed on the other computers i need to work on?
in my downloads folder there is only 3 files.the uninstall_portable has type - windows media player...???
somewhere else i saw it has like 6-8 files there...now i can't find where that was.....
uninstalltool_setup does that have the text file in there with the license?
i'm using vista
geez.....some more help contents would be great....
just a simple - follow these steps list....how about it ???
i'm using vista
We're sorry about your experience.
Every buyer of portable version receives an email with an easy howto:
For portable version: registration data should be saved to the text file "license.dat" which should be placed into the program folder. The data should be of the following format:
The first line - registration name
The second line - registration code
Example:
John Smith
KGT4-YGRT-GHTR-7G31
Portable version download link:
http://www.crystalidea.com/downloads/un ... rtable.zip
Anyway, we're going to add this to the online help.
Thank you
Example:
John Smith
KGT4-YGRT-GHTR-7G31
Thank you
thanks, but what i got in the email i have no problem with.
did you read what i wrote ?
tell me the steps to put what i need on the flash drive...
and read the previous what i wrote...
thanks.....
"perfect support service"
thanks.....
As far as I understand you're unable to run a program on a second computer. What kind of issue do you experience? Some error message? Can you send us a screen? One should distribute the contents of the "uninstalltool_portable.zip" together with license.dat file when running a program on another computer.
