Crash on startup on Windows 8
debush
Post by debush »
Te following info is for Windows 8.
While Macsfancontrol runs manually when run as administrator, it does not start up at boot time. It also will run if the compatablilty mode is set to "Windows XP SP3" and the hard drive is shown in the list, but it still does not starup properly at boot time although it can be manually started, and fan speed is adjusted by drive temperature.
So I reinstalled the Log 5 version and when it tried to startup at boot time the following message was received.
It says Runtime Error
Program C:\Programs Files (x86)\Macs Fan COntrol \MacsFanControl.exe
R6025
- pure virtual function call
The log file is:
INFO 2013-05-06T13:28:45.522 "QMySysInfo::machineName ('')"
INFO 2013-05-06T13:28:45.522 "Starting on iMac11,1"
INFO 2013-05-06T13:28:45.537 "QMySysInfo::machineName ('iMac11,1')"
INFO 2013-05-06T13:28:47.347 "Loading available SMART drives"
INFO 2013-05-06T13:28:47.347 "GetLogicalDrives returned 1020"
INFO 2013-05-06T13:28:47.347 "Checking drive C:\"
INFO 2013-05-06T13:28:47.347 "Drive is fixed"
INFO 2013-05-06T13:28:47.347 "Phisical disk number: 0"
INFO 2013-05-06T13:28:47.425 "Adding drive \\.\PHYSICALDRIVE0"
INFO 2013-05-06T13:28:47.425 "Adding drive WDC WD2001FASS-00U0B0"
INFO 2013-05-06T13:28:47.425 "Checking drive D:\"
INFO 2013-05-06T13:28:47.425 "The drive is NOT fixed (5)"
INFO 2013-05-06T13:28:47.425 "Checking drive E:\"
INFO 2013-05-06T13:28:47.425 "Drive is fixed"
INFO 2013-05-06T13:28:47.425 "Phisical disk number: 0"
INFO 2013-05-06T13:28:47.425 "Checking drive F:\"
INFO 2013-05-06T13:28:47.425 "Phisical disk number: 1"
WARN 2013-05-06T13:28:47.440 "Failed to get SMART_GET_VERSION, GetLastError() = 50"
INFO 2013-05-06T13:28:47.440 "Checking drive G:\"
INFO 2013-05-06T13:28:47.440 "Drive is fixed"
INFO 2013-05-06T13:28:47.440 "Phisical disk number: 1"
INFO 2013-05-06T13:28:47.440 "Checking drive H:\"
INFO 2013-05-06T13:28:47.440 "Checking drive I:\"
INFO 2013-05-06T13:28:47.440 "The drive is NOT fixed (2)"
INFO 2013-05-06T13:28:47.440 "Checking drive J:\"
INFO 2013-05-06T13:28:47.440 "QFanControl::Init: number of supported SMC sensors: 10"
INFO 2013-05-06T13:28:47.440 "QFanControl::Init: number of supported SMART sensors: 1"
INFO 2013-05-06T13:28:47.815 "QFanControlMainWindow::FillFansTable: number of fans: 3"
INFO 2013-05-06T13:28:47.815 "QFanControlMainWindow::FillFansTable: adding fan ODD"
INFO 2013-05-06T13:28:47.815 "QFanControlMainWindow::FillFansTable: adding fan HDD"
INFO 2013-05-06T13:28:47.815 "QFanControlMainWindow::FillFansTable: adding fan CPU"
INFO 2013-05-06T13:28:47.815 "QFanControlMainWindow::FillSensorsTable: number of supported sensors: 11"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor Ambient (TA0P)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Core 0 (TC0C)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Heatsink (TC0H)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Core 1 (TC1C)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor GPU Diode (TG0D)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor GPU Heatsink (TG0H)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor LCD proximity (TL0P)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor Optical Drive (TO0P)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor Mem Controller (Tm0P)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor Power Supply Primary (Tp1P)"
INFO 2013-05-06T13:28:49.923 "QFanControlMainWindow::FillSensorsTable: adding sensor WDC WD2001FASS-00U0B0 (WDC WD2001FASS-00U0B0)"
Dale
Re: Crash on startup on Windows 8
Does it happen on Windows 8 only?
Does it happen only on startup? Every time?
Does it happen with compatity mode set to Windows XP?
Does it happen when setting running as admin in compatibility mode?
Thanks :smile:
debush
Post by debush »
I do not know about Windows 7, need to install win 7.
if run as administrator, or in Windows XP sp3, I do not get the error message at boot time but it does not startup upon booting. If manually started it works fine.
Need to think about problem more.
I may load Windows 7 with only installing the Mac Drivers and test tonight.
Dale
I'll make beta 5 running only under admin rights so there won't be any crash.
debush,
any error message?
I don't think it will change a lot, actually
debush
Post by debush »
Windows 7 if started in compatibility Windows XP SP3 mode or if started as Administrator works okay and will start up at boot time.
Windows 8 if started in compatibility Windows XP SP3 mode or as Administrator sees the HD but will NOT start up automatically at boot time. After Windows is booted if you click the shortcut on the desktop it starts and works properly. I am giving up on Windows 8 on the iMac with the replaced HD and may actullaly no longer use Windows on the iMac
I think that this version should work
http://www.crystalidea.com/downloads/ma ... p_test.exe
