I get an immediate crash on launch on my 2010 27" iMac quad-i7. I'm hoping to use this app to tame the fans due to the well known temperature sensor issue after replacing the factory Samsung (HD103SJ) drive with a WD (WD2001FASS) drive. With the HDD upgrade I also installed an SSD and fused the HDD and SSD as a home grown fusion drive. I have uninstalled all the other fan apps I have tested, including fan control daemon left behind by one of the others.
I've attached the crash log, seems like it might be related to something called "QtGui"? (BTW, when this app crashes, the crash reporter doesn't automatically launch for some reason.)
Any thoughts? Thank you.
Immediate crash on launch, Mac OS X 10.8.3 (beta 5)
Re: Immediate crash on launch, Mac OS X 10.8.3
Attached crash report:
- crash_report.txt.zip
- (12.26 KiB) Downloaded 2029 times
NoisyiMac,
Thank you for such useful report. I'll fix this problem very soon, please stay in touch in this thread!
Please use this version, it should work, if yes I'll add this fix to the next release:
http://www.crystalidea.com/downloads/ma ... l_test.zip
I've only been using this new version for 10 minutes, but so far great! No crash on startup, and my fans have instantly been quieted! Very promising...thank you
Sounds good
