My only concern with Uninstall Tool is if I do uninstall could lose all my snapshots which would be very bad so feel update is the only course of action. If I get your approval all is well in using the update function will do so. Thank you & love this product
Uninstall Tool Update
When there is a new version of Uninstall Tool should I just update it or Uninstall the program and install the new update. I usually never use update features because after many updates they sometimes run into issues.
Re: Uninstall Tool Update
We do release all updates with saving all the features and fixing problems/issues. You can safely update to the latest version 3.3.1 WITHOUT removing existing installation. All your Install Tracker snapshots will be saved.
Alright understood. Issue is when I click check update it doesn't install the update just notifies me of a new version. Do I need to download the new version and install and overwrite the existing Uninstall Tool? or do I need to uninstall the old version and install the new version?
ExactlyDo I need to download the new version and install and overwrite the existing Uninstall Tool?
