Correct location of licence.dat for portable version
pcsupport
Post by pcsupport »
I have the portable version with the licence.dat in the same folder as uninstalltool.exe however it still claims to be an unregistered version.
The licence.dat file is in the correct format.
How can this be fixed?
Re: Correct location of licence.dat for portable version
The location is correct, but you should make sure to enter portable license key.
For you case it's last 4 characters are B56H
pcsupport
Post by pcsupport »
It's all correct as far as I can tell but it still insists that it is an unregistered version.
Just emailed you a checked valid license.dat with your license
pcsupport
Post by pcsupport »
And it works perfectly.
How odd.
Many thanks.
It must have been some typo
