CPU Current RPM = 0
Mrfreak
CPU Current RPM = 0
Post by Mrfreak »
The CPU RPM is 0. All other component values are fine. Any help?
Re: CPU Current RPM = 0
Please post a screenshot of the app
Mrfreak
Post by Mrfreak »
Ive been trying to upload the screenshot in .Tiff and .JPG formats without luck. Any other way or format?
Your system keeps giving me an error message. Basically, no matter witch sensor-value, automatic or constant value I chose, CPU current RPM value still 0. Theres no other app of this kind installed in my iMac.
Please try using PNG, or use other image upload hosting: postimage.org imageshack.us etc
Mrfreak
Post by Mrfreak »
Here is the image:
1. Can you actually hear the fan? Maybe it's physically not working (broken connector, etc)
2. Does reboot help?
Mrfreak
Post by Mrfreak »
Yes, I reboot the machine and even reset the System Management Controller (SMC) and uninstall/install. I hear a load fan but not sure which one is it. Like you said, maybe it's hardware :(
I'd recommend running Apple Hardware Test
