crash on Macpro 3,1
W_h_k
crash on Macpro 3,1
Post by W_h_k »
Just as the previous 2 versions, 1.1.0 crashes within seconds after displaying information on my MacPro3,1 10.8.4.
Crash log:
crash.txt
(38.42 KiB) Downloaded 1159 times
Re: crash on Macpro 3,1
Thank you very much for this useful report, the problem will be fixed soon!
Please run:
1. ls -lea /usr/local/lib
2. ls -lea /usr/lib
W_h_k
Post by W_h_k »
Attached logs:
usrlocallib.txt
(8.13 KiB) Downloaded 969 times
usrlib.txt
(20.98 KiB) Downloaded 1050 times
Temporary workaround is removing (renaming) these 2 files
/usr/local/lib/libssl.dylib
/usr/local/lib/libssl.0.9.8.dylib
W_h_k
Post by W_h_k »
Steven wrote:Temporary workaround is removing (renaming) these 2 files
What are the effects on other software?
I can't say. It shouldn't affect generally, but I'd rename them in case some software (that installed it) refuses to work.
Did it help?
one more possible workaround: copy file /usr/lib/libcrypto.0.9.8.dylib to /usr/local/lib/
Fixed in 1.1.1
W_h_k
Post by W_h_k »
Steven wrote:Fixed in 1.1.1
Confirmed. Thank you!
