Hi
Fancontrol is working fine on a MacMini, but i found a crash report.
Just to inform You about, maybe it helps You.
Report is attached as a text file, direct from Tinkertool System.
Crash Report from MacMini
- MacsFanControl_2013-10-07-152126_MiniMac.txt
- Crash repot witch was sending to Apple.
- (35.06 KiB) Downloaded 832 times
MacPro 5.1 OSX 10.9.5
Crash Report from MacPro
And here one from the MacPro
- MacsFanControl_2013-10-04-162338_Mac-Pro.txt
- MacPro crash report
- (38 KiB) Downloaded 791 times
Re: Crash Report from MacMini
1. MacMini, please make sure to use the latest version 1.1.5
2. MacPro, same here, please make sure to use the latest version 1.1.5
The most important thing is to post technical information (found in the About dialog) for your mac model. Technical information must be also obtained with the latest version of the app.
Main window screenshot is highly desirable as well.
Thank you.
Thank you.
