We have discontinued this forum and moved support tickets to the GitHub issue tracker.
More info
user0815
Posts: 2 Joined: 27 Oct 2013, 15:57
Post
by user0815 » 27 Oct 2013, 16:03
just wanted to ask if you plan to support the late 2013 Retina MacBooks. I really enjoyed your Application on the Macbook Air, so that would be cool.
Is it recommended to try the current version? The fan layout of the Retina 13 inch model has changed, so I prefer to be a little bit cautious (only one fan left).
Thanks!
Posts: 2294 Joined: 21 Dec 2009, 11:48
Post
by Steven » 27 Oct 2013, 16:08
The current version of the app is compatible with any Mac model
I'd be very grateful if you share a screenshot of the main window of Macs Fan Control and technical information from the about dialog (running on your macbook)
user0815
Post
by user0815 » 27 Oct 2013, 22:37
Thanks for your quick reply. I tried it out and it seems to work just fine!
Don't know if you still need the technical details, but here they are:
Macs Fan Control 1.1.6, MacBookPro11,1, Mac OS X Unknown
Right Side-min{1294}curr{1295}max{6175}mode{0}
TA0P (Ambient) - 36.125
TB0T (Bottom Enclosure) - 32.2969
TB1T (Battery Point 1) - 32.2969
TB2T (Battery Point 2) - 31.0977
TBXT () - 32.2969
TC0C (CPU Core 0) - 46
TC0E () - 49.5742
TC0F () - 51.7578
TC0P (CPU Proximity) - 45.375
TC1C (CPU Core 1) - 47
TCGC () - 47
TCSA () - 46
TCXC () - 47.7031
TH0A () - 36.875
TH0B () - 36.875
TH0C () - -1
TH0F () - -1
TH0R () - -1
TH0V () - 35.3359
TH0a () - 36.875
TH0b () - 36.875
TH0c () - -1
THSP () - -1
TM0P () - 41.5
TMLB () - -1
TPCD () - 45
TW0P (Airport Card) - -1
Th1H () - 38.5
Ts0P (Left Palm Rest) - 32.375
Ts0S () - 35.9102
Ts1S () - 34.3398
overview img1.png (95.76 KiB) Viewed 7733 times
Post
by Steven » 28 Oct 2013, 07:49
Great, thank you
