Crash at shutdown
bryanc
Crash at shutdown
Post by bryanc »
Late 2012 Mac Mini - OSX Mavericks
Frequently get a crash when shutting down the computer. CrashReporter log attached.
Bryan
bryanc
Re: Crash at shutdown
Post by bryanc »
This time with a log file
MacsFanControl_2013-12-15-084159_MacMini.log
(35.37 KiB) Downloaded 1018 times
Please post the main window screenshot and technical information from the About dialog.
Please press the 'L' button in the preferences window, this will enable log. Restart the app, next time the crash will reproduce, please post the log (must be on your desktop).
Thank you.
bryanc
Post by bryanc »
This is the content from the About box. "Mac OS X Unknown" seems odd - I am running Mavericks
I'll enable the log and post it after the next crash
Macs Fan Control 1.1.7, Macmini6,2, Mac OS X Unknown
Exhaust-min{1793}curr{1779}max{5478}mode{2,TC0D,55,80}
TA0P (Ambient) - 40.5
TA0p () - 40.5
TA1P (Ambient 2) - 40.75
TA1p () - 40.75
TC0C (CPU Core 0) - 52
TC0D (CPU Diode) - 53
TC0E () - 54.125
TC0F () - 55.7305
TC0G () - 99
TC0J () - 1.60547
TC0P (CPU Proximity) - 48.375
TC0c () - 52
TC0d () - 53
TC0p () - 48.375
TC1C (CPU Core 1) - 51
TC1c () - 51
TC2C () - 54
TC2c () - 54
TC3C () - 52
TC3c () - 52
TCGC () - 53
TCGc () - 53
TCPG () - 103
TCSC () - 51
TCSc () - 51
TCTD () - -1
TCXC () - 53.2656
TCXc () - 53.2656
TCXr () - -1
TH0A () - -1
TH0B () - -1
TH0C () - -1
TH0F () - 0
TH0O () - -1
TH0X () - -1
TH0a () - -1
TH0b () - -1
TH0c () - -1
TH1A () - -1
TH1B () - -1
TH1C () - -1
TH1F () - 0
TH1O () - 9
TH1X () - -1
TH1a () - -1
TH1b () - -1
TH1c () - -1
TI0P () - 45.75
TI0p () - 45.75
TI1P () - 43.875
TI1p () - 43.875
TM0P () - 46
TM0S (DIMM Module 1) - 49.2773
TM0p () - 46
TMBS () - -1
TP0P () - 48.125
TP0p () - 48.125
TPCD () - 51
TW0P (Airport Card) - 37.875
TW0p () - 37.875
Tp0C (PSU1 Inlet Ambient) - 38.8828
Ts0G () - 49
Ts0S () - 31.6289
bryanc
Post by bryanc »
Restarted the machine and once again Macs Fan Control crashed
Attached the new crashdump. The Macs Fan Control log is too large to attach :(. I've pasted the top few records from the log plus the stuff at the end.
INFO 2013-12-15T22:40:05.661 MacFanControl/app.cpp @ 48 "Macs Fan Control 1.1.7, Mac OS X Unknown, Macmini6,2, Qt 4.8.6"
INFO 2013-12-15T22:40:05.670 MacFanControl/FanControl.cpp @ 349 "QFanControl::Init"
INFO 2013-12-15T22:40:05.670 MacFanControl/FanControl.cpp @ 363 "QFanControl::Init - LoadCachedFansAndTempSensors"
INFO 2013-12-15T22:40:05.670 MacFanControl/FanControl.cpp @ 368 "QFanControl::Init - FilterSupportedTempSensors"
INFO 2013-12-15T22:40:05.672 MacFanControl/FanControl.cpp @ 372 "QFanControl::Init - smc_get_fans_control_mode"
INFO 2013-12-15T22:40:05.672 MacFanControl/FanControl.cpp @ 84 "Fan " 0 ": manual"
INFO 2013-12-15T22:40:05.672 MacFanControl/FanControl.cpp @ 376 "QFanControl::Init - QTempSensorSmart::LoadAvailableSensors"
INFO 2013-12-15T22:40:05.717 MacFanControl/FanControl.cpp @ 380 "QFanControl::Init: number of supported SMC sensors: 9"
INFO 2013-12-15T22:40:05.717 MacFanControl/FanControl.cpp @ 381 "QFanControl::Init: number of supported SMART sensors: 1"
INFO 2013-12-15T22:40:05.782 MacFanControl/FanControl.cpp @ 104 Set fans mode 1
INFO 2013-12-15T22:40:05.782 MacFanControl/MainWindow.cpp @ 475 "QFanControlMainWindow::FillFansTable: number of fans: 1"
INFO 2013-12-15T22:40:05.782 MacFanControl/MainWindow.cpp @ 483 "QFanControlMainWindow::FillFansTable: adding fan Exhaust"
INFO 2013-12-15T22:40:05.782 MacFanControl/MainWindow.cpp @ 499 "QFanControlMainWindow::FillSensorsTable: number of supported sensors: 10"
INFO 2013-12-15T22:40:05.782 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor Airport Card (TW0P)"
INFO 2013-12-15T22:40:05.782 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor Ambient (TA0P)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor Ambient 2 (TA1P)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Core 0 (TC0C)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Core 1 (TC1C)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Diode (TC0D)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor CPU Proximity (TC0P)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor DIMM Module 1 (TM0S)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor PSU1 Inlet Ambient (Tp0C)"
INFO 2013-12-15T22:40:05.783 MacFanControl/MainWindow.cpp @ 508 "QFanControlMainWindow::FillSensorsTable: adding sensor APPLE HDD HTS541010A9E662 (APPLE HDD HTS541010A9E662)"
INFO 2013-12-15T22:40:06.786 MacFanControl/SensorControl.cpp @ 106 "Exhaust: HALF INCREASE ON"
INFO 2013-12-15T22:40:06.786 MacFanControl/SensorControl.cpp @ 111 "Exhaust: Tendency is set to TendencyIncrease, Temperature 58, RPM=1873"
INFO 2013-12-15T22:40:06.786 MacFanControl/SensorControl.cpp @ 376 "Exhaust: Setting fan speed to" 2088
INFO 2013-12-15T22:40:06.978 MacFanControl/FanControl.cpp @ 104 Set fans mode 1
INFO 2013-12-16T08:31:25.699 MacFanControl/SensorControl.cpp @ 376 "Exhaust: Setting fan speed to" 2225
INFO 2013-12-16T08:31:26.764 MacFanControl/SensorControl.cpp @ 156 "Exhaust: Temperature DECREASED to 57"
INFO 2013-12-16T08:31:26.764 MacFanControl/SensorControl.cpp @ 174 "Exhaust: Ignoring temperature change"
INFO 2013-12-16T08:31:26.764 MacFanControl/SensorControl.cpp @ 199 "Exhaust: Tendency is set to TendencyIncrease"
INFO 2013-12-16T08:31:26.764 MacFanControl/SensorControl.cpp @ 376 "Exhaust: Setting fan speed to" 2227
INFO 2013-12-16T08:31:27.830 MacFanControl/SensorControl.cpp @ 156 "Exhaust: Temperature DECREASED to 57"
INFO 2013-12-16T08:31:27.830 MacFanControl/SensorControl.cpp @ 174 "Exhaust: Ignoring temperature change"
INFO 2013-12-16T08:31:27.830 MacFanControl/SensorControl.cpp @ 199 "Exhaust: Tendency is set to TendencyIncrease"
INFO 2013-12-16T08:31:27.830 MacFanControl/SensorControl.cpp @ 376 "Exhaust: Setting fan speed to" 2229
INFO 2013-12-16T08:31:28.895 MacFanControl/SensorControl.cpp @ 156 "Exhaust: Temperature DECREASED to 57"
INFO 2013-12-16T08:31:28.895 MacFanControl/SensorControl.cpp @ 174 "Exhaust: Ignoring temperature change"
INFO 2013-12-16T08:31:28.895 MacFanControl/SensorControl.cpp @ 199 "Exhaust: Tendency is set to TendencyIncrease"
INFO 2013-12-16T08:31:28.895 MacFanControl/SensorControl.cpp @ 376 "Exhaust: Setting fan speed to" 2231
INFO 2013-12-16T08:31:29.960 MacFanControl/SensorControl.cpp @ 156 "Exhaust: Temperature DECREASED to 57"
INFO 2013-12-16T08:31:29.961 MacFanControl/SensorControl.cpp @ 199 "Exhaust: Tendency is set to TendencyDoNothing"
INFO 2013-12-16T08:31:32.991 MacFanControl/MainWindow.cpp @ 680 "waitForThreadsFinished: m_ThreadUpdate = 1, m_ThreadInit = 0, m_ThreadControl = 1"
INFO 2013-12-16T08:31:33.192 MacFanControl/MainWindow.cpp @ 680 "waitForThreadsFinished: m_ThreadUpdate = 1, m_ThreadInit = 0, m_ThreadControl = 1"
INFO 2013-12-16T08:31:33.393 MacFanControl/MainWindow.cpp @ 680 "waitForThreadsFinished: m_ThreadUpdate = 0, m_ThreadInit = 0, m_ThreadControl = 1"
INFO 2013-12-16T08:31:33.593 MacFanControl/MainWindow.cpp @ 680 "waitForThreadsFinished: m_ThreadUpdate = 0, m_ThreadInit = 0, m_ThreadControl = 1"
INFO 2013-12-16T08:31:33.794 MacFanControl/MainWindow.cpp @ 680 "waitForThreadsFinished: m_ThreadUpdate = 0, m_ThreadInit = 0, m_ThreadControl = 1"
INFO 2013-12-16T08:31:33.994 MacFanControl/MainWindow.cpp @ 701 waitForThreadsFinished: Quit OK
MacsFanControl_2013-12-16-081712_MacMini.log
(35.58 KiB) Downloaded 1114 times
Hello, this issue is fixed. Will be available soon in 1.1.8 version. Thank you!
bryanc
Post by bryanc »
Great - thanks for the response
Bryan
bryanc
Does it work fine for you in version 1.1.8.1 ?
bryanc
Post by bryanc »
Seems fine now. I just rebooted and no crash at shutdown. Startup (I have it installed as a login item) worked fine too.
Bryan
Great!
