Ted1969
Alcohol 120% CCD image to iso
15 Dec 2013, 21:11
Just bought AnyToISO and having difficulty converting any ccd images successfully. I'm uploading a couple of examples to the FTP at the moment.
Thanks for your assistance.
Ted
Re: Alcohol 120% CCD image to iso
19 Dec 2013, 17:51
Thank you, will reply soon.
20 Dec 2013, 12:37
Please ignore message "img_convert failed", the ISO file is created fine created for these 2 IMG files.
Will remove this wrong error message in the next update.
Thank you.
Ted1969
20 Dec 2013, 18:36
They still fail to load within ePSXe or no$PSX emulators - I haven't tried burning them back to CD to see if that works, so it could be an emulator issue. The .iso images created are almost 100MB smaller than the .img files and I'm guessing the .sub data is discarded too ?
Ted
27 Dec 2013, 11:26
These images are not correctly supported because they contain more than 1 track of data, while ISO file can only contain a single data track
Users browsing this forum: No registered users and 0 guests
