Problem when putting to sleep / closing lid (10.9 on MBP4,1)
mfearon
Post by mfearon »
I just downloaded MFC and I am using it on Mavericks-
it's working great on a balky old MacBookPro4,1 (A1260)
that wants to hang whenever the GPU goes over 138.2degF.
It keeps the GPU within range without crashing!
When I leave the machine sit with the lid up and Idle,
it will drift off to sleep with the fans off-
I can then close the lid and it will wake up later,
when the lid is opened without having drained the battery- perfect!
The problem is when I put it to sleep while it is running- by either:
a. closing the lid, b. putting it to sleep with a menu pulldown, or
c. putting it to sleep with a power button tap (same as b).
It doesn't make that perfect, graceful transition to sleep with fans off-
the fans stay running at the same speed, the mac doesn't go to sleep,
and it crashes- is really hot when try to get it going again--
have to force-power-off and let it cool down for 10 min!
Is there a setting somewhere that I missed?
Perhaps a related "energy saver" in all those Sys Prefs?
Re: Problem when putting to sleep / closing lid (10.9 on MBP4,1)
Do you mean that MFC prevents the computer to go to sleep mode?
Please post a screenshot of the main window of MFC and post technical information from the about dialog of the app.
mfearon
Post by mfearon »
Not at all! MFC performs PERFECTLY when the MBP is left idly running with the lid up!
(I apologize for thr detailed, long-winded, confusing description of the problem)
My problem is when I want to slam the lid shut and dash off
with the laptop under my arm...
MFC doesn't automatically go thru the same perfect transition
to a cool, sleeping, non-battery eating state!
MFC version 1.1.7
MacOS 10.9
A1260 = MacBookPro4,1
I'll send the Screen shots & Sys profiles
mfearon
Post by mfearon »
I am trying to now to test whether I can get the MBP to
"gently" drift-off-to-sleep with the lid open, then
close lid, open lid, close it again (before the screen sleeps),
and see if it sleeps as gently as the first time- hasn't done it yet!
You have a tough road with MFC...
many people with damaged computers try to use it to keep them running.
I thought I had reattached the big heat sink properly with
heat sink compound. but this may not be the only problem.
In my case, I am not familiar with laptops and their cooling problems,
but this mac's SCP did not seem to operate its fans in a manner that
kept the processor from overheating- the fans never got loud, but
setting up MFC to adjust the fans to do this was a cinch!
The system now works for longer period of time,
and I was able to fly xplane for long periods,
pushing the CPU and GPU to the hairy edge of temperature -fans roaring!
Note- I am also using an old program called Temperatur Monitor-
knows all about this old MBP and makes all sorts of whizzy graphs!
Do you think it is conflicting?
Here's the screenshot:
MFC Screen Shot 2013-12-21 at 6.21.45 PM.png (106.59 KiB) Viewed 8650 times
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro4,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 3 MB
Memory: 3 GB
Bus Speed: 800 MHz
Boot ROM Version: MBP41.00C1.B03
SMC Version (system): 1.27f3
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Automatic Restart On Power Loss: No
Wake On AC Change: No
Wake On Clamshell Open: Yes
Wake On LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
PrioritizeNetworkReachabilityOverSleep: 0
Battery Power:
Display Sleep Timer (Minutes): 2
Reduce Brightness: Yes
System Software Overview:
System Version: OS X 10.9 (13A603)
Kernel Version: Darwin 13.0.0
Boot Volume: MBP HD
Boot Mode: Normal
Secure Virtual Memory: Enabled
Time since boot: 1 minute
Macs Fan Control:
Version: 1.1.7
obtained_from: identified_developer
Last Modified: 11/23/13 12:18 AM
Kind: Intel
64-Bit (Intel): No
Location: /Users/markfearon/Downloads/Macs Fan Control.app
Get Info String: 1.1.7
Temperature Monitor:
Version: 4.51
obtained_from: unknown
Last Modified: 6/23/08 7:00 AM
Kind: Universal
64-Bit (Intel): No
signed_by: Marcel Bresink Software-Systeme
Get Info String: Temperature Monitor version 4.51,
Copyright © 2003 - 2008 by Marcel Bresink Software-Systeme
