1.1.8 crashing when try to access preferences...
islandmike
Post by islandmike »
Sometimes it crashes only after trying to make a choice in preferences, sometimes it crashes just with the preference window open before you even have time to make a choice.
I am using 10.9.1, and running 3.2GHZ Intel Core i3, 16GB of memory.
Sample Process and Console logs attached.
Hope that might be helpful.
MacsFanControl_012914.rtf.zip
Sample Process and 4 logs in the Console
(78.06 KiB) Downloaded 800 times
mayersj1
Re: 1.1.8 crashing when try to access preferences...
Post by mayersj1 »
I'm also seeing crashes with 1.1.8. I can't get it to run for more than a minute without crashing.
I've attached the crash report.
mfc_crash_report.zip
(13.03 KiB) Downloaded 801 times
Thank you guys :(
Now fixing the the problem right away. Qt5 transition makes a lot of pain.
Does anyone who experience crash have any of Accessibility settings enabled on Mac?
http://www.apple.com/accessibility/osx/
