No Sensors Available in Pull Down List
Jon_K
Post by Jon_K »
When I double click on a fan in the Macs Fan Control wind & select sensor-based value, then click on the pull-down, I get a whole lot of nothing. The previously selected sensor is the only choice, and greys out when I click on the menu.
Macs Fan Control 1.1.11, MacPro5,1, Mac OS X 10.7
PCI-min{1344}curr{3167}max{4500}mode{2,Te1S,50,69}
PS-min{600}curr{835}max{2800}mode{0}
EXHAUST-min{600}curr{745}max{2800}mode{2,TCAH,50,75}
INTAKE-min{600}curr{599}max{2800}mode{2,TCAH,55,70}
BOOSTA-min{800}curr{798}max{5200}mode{2,TCAH,55,80}
BOOSTB-min{800}curr{799}max{5200}mode{2,TCBH,55,80}
TA0P (Ambient) - 33.625
TCAC (CPU A core from PCECI) - 50.6875
TCAD () - 53.25
TCAG () - 80
TCAH (CPU A HeatSink) - 51.125
TCAS () - 51.125
TCBC (CPU B core from PCECI) - 58.0469
TCBD () - 47.375
TCBG () - 80
TCBH (CPU B HeatSink) - 43.875
TCBS () - 43.875
TH1F () - 32.0586
TH1P (Drive Bay 1) - 32.125
TH1V () - 33.625
TH2F () - 32.5547
TH2P (Drive Bay 2) - 32.5
TH2V () - 33.625
TH3F () - 32.7461
TH3P (Drive Bay 3) - 32.75
TH3V () - 33.625
TH4F () - 33.0781
TH4P () - 33
TH4V () - 33.625
THPS () - 33.625
THTG () - 58
TM1P () - 42.625
TM2P () - 44.75
TM3P () - 51.625
TM4P () - 52.875
TM5P () - 52.75
TM6P () - 56.625
TM7P () - 47.5
TM8P () - 39.25
TMA1 () - 42.25
TMA2 () - 45.25
TMA3 () - 46.5
TMA4 () - -1
TMB1 () - 40.5
TMB2 () - 40.25
TMB3 () - 39.75
TMB4 () - -1
TMHS () - 46.5
TMLS () - 39.75
TMPS () - 46.5
TMPV () - 40.2773
TMTG () - 75
TN0D (Northbridge Chip) - 90.125
TN0H (IOH HeatSink) - 76.375
TNTG () - 65
Te1F () - -1
Te1P (PCIE Ambient) - 34.125
Te1S (PCIE slot 1) - 61
Te2F () - -1
Te2S (PCIE slot 2) - -1
Te3F () - -1
Te3S (PCIE slot 3) - -1
Te4F () - -1
Te4S (PCIE slot 4) - -1
Te5F () - -1
Te5S () - -1
TeGG () - 85
TeGP () - 0
TeRG () - 60
TeRP () - 0
Tp0C (PSU1 Inlet Ambient) - 56
Tp1C (PSU1 Secondary Component) - 54
TpPS () - 56
TpTG () - 90
Re: No Sensors Available in Pull Down List
Jon_K
When does this happen? I mean was there anything on this Mac that preceeded this issue.
Please also provide a screenshot of the issue.
Jon_K
Post by Jon_K »
It always happens, It never does not happen. I can never change sensors.
>>was there anything on this Mac that preceeded this issue ??
Everything else on this mac is working fine.
Before click:
Screen Shot 2014-06-25 at Jun 25, 2014 9.00.03 PM.png (103.08 KiB) Viewed 24689 times
After click:
Screen Shot 2014-06-25 at Jun 25, 2014 9.00.26 PM.png (100.61 KiB) Viewed 24689 times
Why is "CPU B HeatSink" selected?
When you open this window initially there should be "Ambient".
Try clearing MFC preferences (first quit) by executing these 2 commands:
rm ~/Library/Preferences/com.crystalidea.MacsFanControl.plist
killall -u me cfprefsd
Jon_K
Post by Jon_K »
Why is "CPU B HeatSink" selected? Because that is the fan I wish to change, obviously.
I decided to reinstall Macs Fan Control from a zip. Version 1.1.8.1 works fine.
When I went to Check for Updates to upgrade to the newest version, the Install and relaunch does not work. The program never relaunches. When I manually relaunch the program, I get 1.1.8.1.
Jon_K
The latest version is 1.1.11
http://crystalidea.com/macs-fan-control-changelog
Please make sure to use it. The auto-update issue is fixed there as well.
Jon_K
Post by Jon_K »
OK, 1.1.11 installed.
But none of this solved the original problem. When I double-click on a fan [ANY FAN] & select Sensor-based Value, the pull-down menu allows only Ambient. No other sensors are available.
Jon_K
Do you have access to some other mac to check if this behavior repeats?
Jon_K
Post by Jon_K »
No
