Mac fan set minimum speed
I heard setting the minimum speed was going to be implicated a few months ago. Is there an eta on when it will come out? It would be a very useful feature. I have no way of setting my minimum fan speed above 2k on my macbook pro running boot camp. I can only set a constant speed..
Re: Mac fan set minimum speed
mgbigair
Yes, it's going to be done soon. We need to collect as much technical information from the About dialog as possible.
Can you share yours?
Great thanks
Here you go
Macs Fan Control 1.1.11, MacBookPro8,2, Windows 7
Left side-min{2000}curr{6196}max{6200}mode{0}
Right side-min{2000}curr{6200}max{6200}mode{0}
TB0T (Bottom Enclosure) - 32.5
TB1T (Battery Point 1) - 32.5
TB2T (Battery Point 2) - 31.7969
TC0C (CPU Core 0) - 97.625
TC0D (CPU Diode) - 93.375
TC0E () - 98.0703
TC0F () - 98.9648
TC0P (CPU Proximity) - 75.375
TC1C (CPU Core 1) - 97
TC2C () - 97
TC3C () - 99
TC4C () - 96
TCGC () - 98
TCSA () - 89
TCTD () - -1
TG0D (GPU Diode) - 74
TG0P () - 64.5
THSP () - 48
TM0S (DIMM Module 1) - 50.9375
TMBS () - 0
TP0P () - 68.125
TPCD () - 75
TW0P (Airport Card) - -1
Th1H () - 57.75
Th2H () - 55.375
Tm0P (Mem Controller) - 49.125
Ts0P (Left Palm Rest) - 30.3125
Ts0S () - 50.0898
Here you go
TC0E () - 98.0703
TC0F () - 98.9648
TC2C () - 97
TC3C () - 99
TC4C () - 96
TCGC () - 98
TCSA () - 89
TCTD () - -1
TG0P () - 64.5
THSP () - 48
TMBS () - 0
TP0P () - 68.125
TPCD () - 75
Th1H () - 57.75
Th2H () - 55.375
Ts0S () - 50.0898
mgbigair
Great!
Great!
No problem, as you can see my computer runs very warn with an external display connected. On the mac side of things i like to run the fans at 4k to keep the temps down to a normal 55-70C . But when the computer starts to get really hot i would like the smc to kick into auto. Only way to do that is to set min fan speed which is what i'm sure many other boot camp users would like.
Thanks again for a fast response.
Jumping into the topic, here my techical info. Just to clarify: when talking about setting different minimun fan speed we mean just adjusting the min rpm that the fan spins but when the temps rise the fan speed is control by the system like in auto mode?
Macs Fan Control 1.1.11, Macmini6,1, Mac OS X 10.9
Exhaust-min{1800}curr{1796}max{5500}mode{0}
TA0P (Ambient) - 45.75
TA0p () - 45.75
TA1P (Ambient 2) - 45.375
TA1p () - 45.375
TC0C (CPU Core 0) - 59
TC0D (CPU Diode) - 58.5
TC0E () - 59.3516
TC0F () - 61.1523
TC0G () - 99
TC0J () - 1.80078
TC0P (CPU Proximity) - 51.75
TC0c () - 59
TC0d () - 58.5
TC0p () - 51.75
TC1C (CPU Core 1) - 58
TC1c () - 58
TCGC () - 58
TCGc () - 58
TCPG () - 103
TCSC () - 56
TCSc () - 56
TCTD () - -1
TCXC () - 59.3594
TCXc () - 59.3594
TCXr () - -1
TH0A () - -1
TH0B () - -1
TH0C () - -1
TH0F () - 0
TH0O () - -1
TH0X () - -1
TH0a () - -1
TH0b () - -1
TH0c () - -1
TH1A () - -1
TH1B () - -1
TH1C () - -1
TH1F () - 0
TH1O () - 9
TH1X () - -1
TH1a () - -1
TH1b () - -1
TH1c () - -1
TI0P () - 46.875
TI0p () - 46.875
TI1P () - 46
TI1p () - 46
TM0P () - 49.375
TM0S (DIMM Module 1) - 51.9453
TM0p () - 49.375
TMBS () - -1
TP0P () - 52
TP0p () - 52
TPCD () - 52
TW0P (Airport Card) - 45.125
TW0p () - 45.125
Tp0C (PSU1 Inlet Ambient) - 41.4375
Ts0G () - 49
Ts0S () - 37.3008
TA0p () - 45.75
TA1p () - 45.375
TC0E () - 59.3516
TC0F () - 61.1523
TC0G () - 99
TC0J () - 1.80078
TC0c () - 59
TC0d () - 58.5
TC0p () - 51.75
TC1c () - 58
TCGC () - 58
TCGc () - 58
TCPG () - 103
TCSC () - 56
TCSc () - 56
TCTD () - -1
TCXC () - 59.3594
TCXc () - 59.3594
TCXr () - -1
TH0A () - -1
TH0B () - -1
TH0C () - -1
TH0F () - 0
TH0O () - -1
TH0X () - -1
TH0a () - -1
TH0b () - -1
TH0c () - -1
TH1A () - -1
TH1B () - -1
TH1C () - -1
TH1F () - 0
TH1O () - 9
TH1X () - -1
TH1a () - -1
TH1b () - -1
TH1c () - -1
TI0P () - 46.875
TI0p () - 46.875
TI1P () - 46
TI1p () - 46
TM0P () - 49.375
TM0p () - 49.375
TMBS () - -1
TP0P () - 52
TP0p () - 52
TPCD () - 52
TW0p () - 45.125
Ts0G () - 49
Ts0S () - 37.3008
theomoto
Thanks, we didn't have MacMini6,1 in the database.
Yes. But I'm also thinking of changing min speed when using MFC sensor-based mode.when talking about setting different minimun fan speed we mean just adjusting the min rpm that the fan spins but when the temps rise the fan speed is control by the system like in auto mode?
No problem!
The idea changing the min fan speed sensor based mode is great step to a good direction, but I think that the "ultimate" Mac Fan Control will be if you could implement a graph to give the user the ability to map out his own fan speed curves just like the following picture: http://images.anandtech.com/doci/6530/nzxt1.jpg
This, plus the ability to save the curves as profiles, I think is the way to go-I know it's a long one-.
Where can I download this program?
There are a bunch of pc parts makers that have invested in such programs for monitoring and adjusting cooling. These programs work only on windows and sometimes with specified hardware/coolers. If it is any help the most popular are corsair and nzxt. The correspoding links are http://www.corsair.com/en/support/downloads and http://cam.nzxt.com/.
mgbigair
in the TODO listchanging min speed when using MFC sensor-based mode
