Don't know if this is a Mac problem or a Fan Control problem, but I'm seeing it a lot:
7/30/14 6:25:09.000 AM kernel[0]: process MacsFanControl[1311] caught causing excessive wakeups. Observed wakeups rate (per sec): 377; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 4533535
7/30/14 6:25:09.643 AM ReportCrash[30692]: Invoking spindump for pid=1311 wakeups_rate=377 duration=120 because of excessive wakeups
7/30/14 6:25:09.000 AM kernel[0]: CODE SIGNING: cs_invalid_page(0x10efe7000): p=30693[spindump] final status 0x0, allowing (remove VALID) page
7/30/14 6:25:10.803 AM spindump[30693]: Saved wakeups_resource.spin report for MacsFanControl version 1.1.12.1 (???) to /Library/Logs/DiagnosticReports/MacsFanControl_2014-07-30-062510_2011-mini.wakeups_resource.spin
spindump and wakeup?
Re: spindump and wakeup?
hank
http://forums.crystalidea.com/viewtopic.php?f=11&t=1006
+ post here
Does it happen when the app is minimized?
+ post here
[attachment=0]Screen Shot 2014-07-30 at 9.55.52 AM.png[/attachment]Macs Fan Control 1.1.12.1, Macmini5,1, Mac OS X 10.9
Exhaust-min{3588}curr{3586}max{5500}mode{2,TC0D,51,59}
TA0P (Ambient) - 32.625
TA0p () - 32.625
TA1P (Ambient 2) - 34.625
TA1p () - 34.625
TC0C (CPU Core 0) - 46
TC0D (CPU Diode) - 40.25
TC0E () - 46.043
TC0F () - 47.6172
TC0G () - 94
TC0J () - 1.57422
TC0P (CPU Proximity) - 38.25
TC0c () - 46
TC0d () - 40.25
TC0p () - 38.25
TC1C (CPU Core 1) - 42
TC1c () - 42
TCGC (PECI GPU) - 44
TCGc () - 44
TCPG () - 98
TCSC () - 39
TCSc () - 39
TCTD () - 0.0390625
TCXC () - 45.6094
TCXc () - 45.6094
TI0P () - 37.375
TI0p () - 37.375
TI1P () - 36.25
TI1p () - 36.25
TM0P () - 42.5
TM0S (DIMM Module 1) - 44.2227
TM0p () - 42.5
TMBS () - 50
TP0P () - 38.125
TP0p () - 38.125
TPCD () - 47
TW0P (Airport Card) - 31.25
TW0p () - 31.25
Tp0C (PSU1 Inlet Ambient) - 37.793
TA0p () - 32.625
TA1p () - 34.625
TC0E () - 46.043
TC0F () - 47.6172
TC0G () - 94
TC0J () - 1.57422
TC0c () - 46
TC0d () - 40.25
TC0p () - 38.25
TC1c () - 42
TCGc () - 44
TCPG () - 98
TCSC () - 39
TCSc () - 39
TCTD () - 0.0390625
TCXC () - 45.6094
TCXc () - 45.6094
TI0P () - 37.375
TI0p () - 37.375
TI1P () - 36.25
TI1p () - 36.25
TM0P () - 42.5
TM0p () - 42.5
TMBS () - 50
TP0P () - 38.125
TP0p () - 38.125
TPCD () - 47
TW0p () - 31.25
- Screen Shot 2014-07-30 at 9.55.52 AM.png (116.39 KiB) Viewed 13306 times
log file attached as "wakeups.txt"
- wakeups.txt
- (35.81 KiB) Downloaded 1097 times
Wakeups report appears when the app is minimized?
Crash is in the new topichank wrote:Yes, the wakeups appeared in Console while MacsFanControl was minimized to the top bar on the screen.
It's not just MFC though.
Last night, I completely reinstalled OSX and the Combo update; didn't fix the problems.
A different wakeup, just to show it's other things too:
7/31/14 11:00:17.000 AM kernel[0]: process WindowServer[539] caught causing excessive wakeups. Observed wakeups rate (per sec): 189; Maximum permitted wakeups rate (per sec): 150; Observation period: 300 seconds; Task lifetime number of wakeups: 214668
7/31/14 11:00:19.741 AM spindump[1948]: Saved wakeups_resource.spin report for WindowServer version ??? (???) to /Library/Logs/DiagnosticReports/WindowServer_2014-07-31-110019_2011-mini.wakeups_resource.spin
