Folks,
I busted the hard drive sensor (the one that sticks to the housing) when updating internal components in my 2009 Mac Mini. As predicted, the fans ran full bore when I turned it on. I use Macs Fan Control to deal with the problem. Two questions:
1 - Will my Mini still shut off automatically if the CPU, for example, exceeds safe temperatures?
2 - My Northbridge Chip is around 80C when I'm doing minimal things like running a browser to type this and playing a BBC Flash stream (see attached image). Is that an acceptable temp for this chip or should I do something about it?
Thanks!
Mac Mini 2009 with busted hard drive sensor
- Screen Shot 2014-09-05 at 8.22.33 AM.png (32.04 KiB) Viewed 7293 times
Re: Mac Mini 2009 with busted hard drive sensor
1. As far I know, it won't shut down. Check max temp for your cpu here (and post results as well)
http://forums.crystalidea.com/viewtopic.php?f=11&t=1073
2. It's acceptable.
2. It's acceptable.
A radom quote from the internet:
"The Intel processors used in Macs are designed to automatically shut down to prevent damage if they truly overheat."
Is this true?
Thanks for your quick responses here and for a great product!
R
Is this true?
R
Never heard about it. Check max temp for your cpu at the link above.
