Kernel panics
ssharber
Kernel panics
Post by ssharber »
Hi, first I just want to say that of all the fan control programs I've tried I love MFC the best. If it was a paid app I'd buy it. (Ok people please don't shoot me for saying that but it's how I feel). I have a MBP, mid 2012 13" model 9,2, with 10.8.5, all updates, and 16gb of ram. I also have a Samsung 840 Pro 256 GB SSD and everything runs fine.
Every time I update past the 1.1.0 version I get kernel panics and have to back down to the 1.1.0 version. I have tried all I know, but can't seem to resolve it. Ive included a crash report in hopes you could tell me whether it is related to a particular program I may have or what it is.
I truly love the app and would hate to start using another one. It's gotten to the point now where every time I restart I get the update message and have to wait 20 seconds before continuing. I hope I've included everything you need. Thank you
Re: Kernel panics with newer versions
Hello and thank you for all the information.
1. Please provide us with a panic report when using 1.1.5 version.
2. Please share you MFC main window screenshot (with temperature in Celcius) and techinical information from the About dialog.
ssharber
Post by ssharber »
Thank you for responding. Have installed newest version and will report with info when it occurs. Again thank you
ssharber
Post by ssharber »
Have finally had another panic...... have included the report simply pasted into textedit. If you need the console report just let me know. Thank you so much.
ssharber
Post by ssharber »
Sorry, forgot the pic of my control panel
Screen Shot 2013-10-26 at 1.48.19 AM.png (65.6 KiB) Viewed 38605 times
Sorry but there's no report. If you cannot attach a .txt file to your post you can use our e-mail. Also we do need techinical information from the About dialog
Thank you, the report is received. Could you please give me some more information, how did it happen?
ssharber
Post by ssharber »
Typically it will happen when I am either surfing the web, and Ill notice my temp will start to rise, probably due to flash content or just cpu usage, and it will panic. other times I can be, burning a dvd and when the cpu gets hot sometimes the fan will ramp up like it is supposed to, and other times it doesn't, and I'll notice that my temps will be like 200 F and then I'll have to go in and manually set the fan speed to 6200 (which is max on my MBP) and then it will finally cool off. But sometimes it will panic before it ever gets up that high. My point is I think it is not responding to the calls for it to ramp up. I don't know whether that causes the panics, I just sometimes see the temp rising and the fan speed not, then it will panic. Hope that helps. If you need further let me know
Does it happen when you manually set some constant RPM value? Or only when using sensor-based control?
I do need to know the values you're using for the sensor-based mode. Please post technical information from the about dialog.
Also we need system log (you can find it in /Applications/Utilities/Console), maybe there're some faulty entries that took precedence of the crash.
ssharber
Post by ssharber »
It happens when setting MFC to use sensor based control and I have it set to use the CPU Core 1 temp sensor. I will include the info you asked for. The values are currently set at 134 and 150, which were the values it automatically set when I changed it to sensor based control. I didnt change the values, they seemed ok to me. I will email the files. When I try to attach them it states they are too big. Thanks
Sorry about the technical info from the about dialog. I finally understood what you were asking me to do. Sorry..... been ill lately. Thanks
ssharber
Post by ssharber »
came home today after leaving the computer for a few hours and had this most recent panic. ive included the report. all other info is the same. thanx
kernel7.txt
(7.73 KiB) Downloaded 2035 times
New version 1.1.7 with optimized SMC writing will be release soon.
Please try version 1.1.7
ssharber
Post by ssharber »
Just browsing the web and had another kernel panic. Was beginning to think that the new version was going to fix it, but seems not. Will include the report.
kernel8.txt
(7.63 KiB) Downloaded 1350 times
Please go to Preferences, then press the 'L' button, it will activate log, then restart the app. Please collect all the log till the next panic.
ssharber
Post by ssharber »
Okay. Log is running. Will let you know. Thank you so much.
ssharber
finally
Post by ssharber »
Well, it has been weeks and weeks without a panic. I had logging enabled. It just NEVER panicked. So I finally just assumed the newer version had fixed the issue and turned off logging. (Mainly because it kept the logs on my desktop and would not allow me to change its location) Well, about a week and a half after I turned off logging, it panicked. I have the logs from before, and the panic report. Im going to send the panic report. If you want the logs I can send them, but they are from when the program didn't panic. I have re-enabled logging and will keep it logging til it panics. Thank you
ssharber
Could you please try version 1.1.8.1 ? We have improved some of potentially unstable things there.
ssharber
Post by ssharber »
My pleasure!
ssharber
Post by ssharber »
less than a day after getting it running, after a long period of no panics, I got one yesterday. Ironically, when I installed the new version, my logging had been disabled. When I went back and tried to re-enable logging, I couldn't get it to enable. Either I forgot how to enable logging, or it just wouldn't enable. So I have just ran it the past day without logging. Ive included the crash report. Please let me know how to rte-enable logging and we'll go from there. Thanks
Newest version panic.txt
(8.05 KiB) Downloaded 2099 times
